Question about Sony Vaio NR VGNNR160ES PC Notebook
Have a Sony VGN-NR160E/S 15.4" VAIO NR Series and
Posted by danessta on
Mike LaPres
  • 757 Answers
Here is the latest update I found;
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGN-NR160ES
Posted on Nov 01, 2010
Viao vgn-nr430e/p just died
remove battery and retry with only ac power connected ..if that works then the battery is bad...if that doesnt work then it could many other things like bios battery, power connector, mobo...
Apr 15, 2013 | SONY VAIO NR Series VGN-NR430E/P NoteBook...
Need updated bios for sony vaio vgn-nr160e/s
Hi danessta,
You can download the BIOS Update for the VGN-NR160E/S from the below link.
ftp://download.sony.com/US/pc/PHBSYS-14612500-US.EXE
Before installing this update, be sure the computer is running from AC power. If the installation of the BIOS is interrupted by power loss, the computer may not operate correctly or at all!
During the installation of this update:
  • Do not turn the computer off.
  • Do not allow the computer to enter Standby or Hibernation states.
  • Do not start other programs.
  • Do not connect any peripherals.
Also please make sure that you're installing the Update for the correctly Computer Model.
The Model # of the Computer can be confirmed from the System Information Window. To open the System Information window, open the Run window and type msinfo32. On the System Information Window, you can located the Model Number of the Computer next to the "System Model".
Good Luck!
Please post back if you require any further assistance.
Thanks for using FixYa.
Nov 01, 2010 | Sony VAIO VGN-NR498E/S Notebook PC
Want to reset Sony VGN-NR160E/s Vaio NB to factory
try the recovery disk or the recovery option of the sony vaio
May 15, 2010 | Computers & Internet
Sony vaio vgn-nr160e with vista, function+ keys wont work
To enable the Fn keys functionality, you need to install the "Vaio Event Service" and "Sony Utility Series"
They are available to download as part of a package from the Sony website. Here is the link:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNNR160E&upd_id=3262&os_id=28
Regards,
Purito
Oct 18, 2009 | Sony VAIO VGN-NR160ET Notebook
Install xp on sony series nr
The BIOS doesn't care nor detect the installed OS and should only be upgraded if you are having BIOS issues.
The old adage "If it works don't try to fix it" certainly applies here.
Sep 07, 2009 | Sony VAIO NR Series VGN-NR485E/T Notebook
I can't boot up the Vista install on a Sony Vaio VGN-NR160E
go to your BIOS Setup, see to it that there is a Hard Disk Boot Priority, maybe you didn't put it there.
Jul 21, 2009 | Sony VAIO VGN-NR160ET Notebook
The LCD screen doesn't turn on when the computer is turned on
Does the power light stay on? You should see the Hard drive light blinking for quite a while after the computer is turned on if the computer is working and the display isn't. Is there a hot key for your laptop that sets lightness and darkness for the display? You might mess with that. If those don't work then you need a professional.
Jun 01, 2009 | Sony VGN-NR185E/S VAIO NR Series
Formating problem
hi i have sony vaio VGN-NR-220E i want to know how i can format this system there vista operating i want Windows xp
Aug 22, 2008 | Sony VAIO VGN-NR220E/S Notebook PC
VAIO VGN-NR160E
You can slove it from the safemode .There are few methods to slove your problem.
Switch on the system.then press F8 go to safemode and after enter into the windows in safemode goto the unistall the program and uninstall the nero and goto start menu, then run type "mcsonfig" goto startup tab and unselect the all the programs in the start up and reboot the system .try it and inform to the fixya.com
May 14, 2008 | Sony VAIO VGN-NR160ET Notebook
Sony Vaio NR VGNNR160ES PC Notebook Logo
333 people viewed this question
Top Sony Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
