Question about Schlage Camelot Deadbolt Keypad, Satin Nickel #FE595VCAMXACC619
I tap the code in i hear the little noise it makes when it unlocks i turn the handle and i cant open the door now i have to use the key thats the only way it works what should i do
Posted by rbaret05 on
Coaltowner
  • 963 Answers
How can I program my electronic keypad lock when the instructions with the programming code have been lost?
The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This number is the programming code referenced in the information for changing the entry code.
This link will take you to the page that you need to get started:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Then scroll down to this heading on that page:
Electronic Security-Keypad Entry Flex-lock FE595/Keypad Entry Auto-Lock FE575 Documents
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This installation video (third item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! Batteries should be replace about every three years.
The eighth item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Posted on Nov 06, 2011
Cant open my hood
Most door locks will operate manually if you lift handle with key turned, then key will turn some more and manually unlock.
Jan 14, 2015 | 1996 Nissan Sentra
Passenger side door on 1998 olds 88 locked and cant get it open even with key
Doubtful. I'd recommend a good locksmith to come pop the lock for you fron the window channel. If you know what to look for, just roll down the window, find the lock linkage, and pop the lock yourself.
Mar 13, 2014 | Oldsmobile Cars & Trucks
How do you use the emergency key (small black plastic key hidden inside the fob) to OPEN my 2008 Passat? Is there a place on the door SOMEWHERE TO PUT THE KEY. duh on me, I can't find it.
I found out what to do, there is a plastic covering on the door handle. Click that off and the use the key in the key fob to unlock the door. You can lock & unlock it.
Feb 11, 2012 | 2008 Volkswagen Passat Sedan
Rear driver door will not open
You can take off the small cover where there is normally a key hole, and access it that way.
Mar 31, 2010 | 2004 Volkswagen Jetta
Power door lock, driver side only, does not work in my '95 Sable
if you here a noise that should mean the little motor (door lock actuator) thar works the door lock is getting power to it and it should be ok. sounds like when you changed the inside latch you must have disturbrd/disconnected the linkage or the clip that connects the lock actuator to the latch assembly(the female V-SHAPED mechanism that engages the POST/STRIKER (male part) its a little hard to name these parts so i am describing them to you. look insidethe door and see if you see any threaded RODS OR LINKAGES that are not connected at both ends.the noise youre hearing is most likely the door lock actuator "spinning"up and down but its unable to lock or unlock the door latch mechanism.
Sep 01, 2009 | 1994 Mercury Sable
WF840 is flashing H20 what is the problem
machine cant take in water, if you hear a quiet hum when a programme is started that will be the inlet valve opening, check the inlet hose isnt kinked, the water tap is on, on the isolator tap sometimes the little handles snap and you cant turn it on or off, remove the handle (littlwe screw on top) and turn it with a small spanner
Jun 09, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
Cant unlock my saab convertible with key
I had this same problem and I fixed it by opening up the door panel and accessing the door handle mechanism by removing the membrane that covers up the access holes. After watching the mechanism work by manually lifting and lowering the lock as well as actuating the door handle, I noticed that the door handle mechanism was causing the lock to bind as a return spring was not letting the mechanism return to neutural after the door handle was actuated. This blocked the mechanism from unlocking even with the key. Believe it or not all that was required was a little wd - 40 on the mechanism and the problem disappeared. The lock once again worked both with the key and with the remote. 15 minutes to take off the door panel 25 minutes to diagnose, 20 minutes to think about what might be causing the spring not to work correctly and less than a minute to remedy. I hope that I can save you the 45 minutes. Good Luck
Apr 28, 2009 | 1996 Saab 900
The Hatch window on my 2002 Astro Van won't open?
To start with , stick the little red nozzle from WD-40 in the key slot as far as you can & spray real good in there. Can you hear lock "thump" when you hit remote for unlock, or open?
Apr 09, 2009 | 2002 Chevrolet Astro
Cant open drivers side back door from inside or out side
you need to remove the inside door panel and see if the clip on the link for the door handles came off .
Feb 21, 2009 | 1999 Dodge Durango
Schlage Camelot Deadbolt Keypad, Satin Nickel #FE595VCAMXACC619 Logo
224 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Mike
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
