Question about Whirlpool Duet GHW9150P Front Load Washer
"Control Locked" lamp is lit on the washer. Tried
Posted by tklotz on
marka19
    President:
  • 1,430 Answers
Press and hold the end of cycle button for 15 seconds this should clear it.
Control locked
Posted on Nov 01, 2010
Controls locked
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start. You can lock the controls while the washer is operating. To lock the controls: Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows. To unlock the controls: Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
Aug 06, 2012 | Whirlpool AWM9000 Front Load Washer
Hello, Re: frontloading washer Model C45172 Our washer has been operating withiout hitch since purchase about five years ago, We love it. Today I tried to program it to do an extra rinse after wash...
For the Elite (HE) machines:
Press 'STOP' twice, press 'POWER', choose a wash cycle (such as 'NORMAL'), select wash options (water temp), press 'START' to finish the reset sequence.
Other Kemore electronic washers:
Unplug the machine for a minute, plug it in. Press 'PAUSE/CANCEL' twice.
Good luck from Detroit, MI.
Jun 12, 2011 | Kenmore Washing Machines
The "Control Locked" light is
Mar 31, 2011 | Washing Machines
The control lock is on. I have tried unplugging it and pushing the cancel pause button and it is still on and I can't do anything because because it is all locked.
Hello
To unlock the controls you can reset the control by pressing the END OF CYCLE button and hold it for 15seconds. This is a common issue with whirlpool duet washers. Please get back to me if you have any other questions.
Kevin
Nov 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control locked light is on and washer won't turn on. Can press "Control On" and Cancel/Pause buttons at the same time to get the power on but won't start.
Looking at the manual of my Whirlpool front loader gives me the following advice...
CONTROL WON’T ACCEPT SELECTIONS
1. Press PAUSE/CANCEL button on the touch-pad twice.
2. Drain the unit, then check that the drain hose and drain
pump filter are clear of foreign objects.
3. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
4. Unplug washer or disconnect power.
5. Check harness connections.
6. Plug in washer or reconnect power.
7. Verify CCU operation by running a Diagnostic test or any
cycle
BTW: The full manual is at http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208182208.pdf
Mar 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Help! I have a whirlpool frt load dryer it is locked (controls)
You need to press and hold the "End of Cycle Signal" button on this model to lock or unlock the control panel. The instructions should be printed directly below the button.
Jun 30, 2009 | Whirlpool GEW9250 Electric Dryer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Dryer
Greetings Inakao,
What you need to do is press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Locked feature.
I hope this helps!
Thank you,
Dorothy
Go Ahead. Use Us.
Jun 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
281 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
