Question about LG RU-42PZ61 42 in. HD-Ready Plasma Television
SOURCE: LG RZ42PX11 PICTURE PROBLEM.
I do not know who was helping you before but the problem you are having can be caused by three boards in the tv each by themselves or in combination. Those are the control board with part#6871QCH053G, the Y- board part #6871QYH036D or the Z-board part#6871QZH041B. Without being able to do voltage and signal measurements directly for you, the Z-board is likely the culprit here. But I will tell you that even experienced tv technicians find themselves swapping one or more of the boards until they fix the problem. I am assuming here of course that you have not had problems with your tv before. The part #s I have given you are for the improved boards that LG has assembled to take care of future similar problems and come with their latest training manual for technicians. God bless and good luck.
Posted on Jan 15, 2009
SOURCE: LG 42lc2d found u502 in power supply blown up.
You won't find a part number for this ic. These boards were made to be replaced as one piece. A new board should do the trick. If you can try to check for a short to ground. Most of the plugs on the board have voltages labeled. If there is a dead short you will see it with an ohm meter.
Posted on Oct 14, 2009
The Number IC is ICE3B1565J MAX 12V 3.3V
Regards!
Vagner CostaWave Corporate Softwarehttp://www.wavecorporate.com
Posted on Apr 10, 2012
SOURCE: My Tv LG 26LC7D have the IC number on board U 101 crash
The chip is not replaced by itself but the whole board most likely these days- component level repairs are not done by these types of equipment.
Posted on Oct 01, 2012
