Televison & Video Logo
Question about Akai Televison & Video
Hi. My AKAI CT 2985 is out of sync in horizontal & Vertical .Now plese tell me how can solve this problem?
Posted by tuhinroy0 on
Anonymous
Sir pls help me. i need akai ct2985 remote control model no. i lost my remote in transit and without it i'm not able to use the tv. my mail id : [email protected] pls help. thanks & regard's. jayaram
Posted on Mar 09, 2011
joginder singh
In 29inch nv model of onida,there is horizontal & vertical sync. out,
Posted on Mar 17, 2014
My akai TV model CT- 2985 WAS RUNNIG WITH SOUNDS ONLY PITCHER IS NOT APPEARING PLZ SOLVE
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in the brand name of your device, [here it is "Akai"]; in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
AKAI Colour Television CT-1419A/AT plus AKAI remote RC-V9A. Television was fine, then went to just a narrow, bright horizontal band across the screen but sound is fine. Suspect my son played with the...
hi,
Its not problem with any setting. Its an internal fault. Vertical scanning output stage has failed in your tv. You have to check the soldering of the vrtical output ic if there is any dry soldering this can happen. try to resoder all the points in the vrtical output stage. IF doesn't help then you have to change the vertical output ic. Have added the picture of the dry soldering point how it looks like. If you need further assistance feel free to contact throug FixYa.
2answers
Akai tv 29 inch model ct 2979 circuit diagram i want this circuit can u arrange for trouble shooting contact [email protected]
I want to get new circuit board for my old akai tv model ct 2979 a 29 inch screen tv whose EST has gone as per mechanic.Kindly tell me where to get & what is the cost? reply to [email protected] or call 09676217007
1helpful
I have akai 2201 television set when i start the tv there comes a horizontal line on the screen with no sound & picture kindly gudie
IT IS VERTICAL OUTPUT SRAGE FAULTY. FIRST CHECK SUPPLY VOLTAGE 18VDC. THEN CHECK OUTPUT VOLEGE 15VDC.IT IS UPNORMAL FINALLY CHANGE VERTICAL OUTPUT IC.BEFORE CHANGING IC CHECK ALL THE COMPANENTS IN THE VERT.STAGE
2helpful
Our tv, a Panasonic # CT-36D11E/CT-36D11 only shows a horizontal thin line across the screen. The sound is fine - any ideas? Is it time to replace or could it be repaired cheaply?
Resolder the vertical IC and replace those capacitors near and next to your vertical IC. If the horizontal line still appears, you may have to replace the IC. Thanks for asking and be caredful!
Picture appears only as a thin, horizontal line...
chk vertical amp /vertical drive i/p from oscillator/power to it/power to vertical amp/chk dry joints-hot area/look at vertcal amp capacitors-swelling etc
3answers
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
1helpful
2answers
LOT no.
AKAI CT2985 I NEED LOT NUMBER PLESS TELL ME
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
