I AM USING GT-B5722 SAMSUNG MOBILE PHONE. YESTERDAY I ADDED SOME NUMBERS TO THE REJECTED LIST AND BECAUSE OF THAT I AM NOT ABLE TO RECEIVE THE CALLS FROM THOSE NUMBERS. PLEASE SUGGEST WHAT SHOULD I DO TO
REMOVE THOSE NUMBERS FROM REJECT LIST
So how does one access the rejected list and complete the transfer to the white list as you suggest?So how does one access the rejected list and complete the transfer to the white list as you suggest?
You can't post conmments that contain an email address.
Remove/Edit the contact from the Rejected List Samsung Duos follow the steps: Menu --> settings --> Application settings --> call --> All calls --> Auto reject. select... That should fix your issue. Goodluck!!!
menu---->.application settings----->.call-------.>all calls----->auto reject------>.reject list
save or delete numbers as you want
use more to delete numbers on reject list
in settings you will find a option answering machine, select and uncheck the blacklisted numbers, this app might be in call option or network setting also, varies with some samsung phones
Solution of Samsung E1085T :
1) put out you sim from your mobile
2) put in a new sim in your mobile and use it
3) put in again your previous sim to your mobile, the numbers you have rejected, they are all will be deleted.
> Settings > Application Settings > Call > All Calls > Auto Reject. You can then set the activation to off or delete a number from the auto reject list.
Remove/Edit the contact from the Rejected List Samsung Duos follow the steps: Menu --> settings --> Application settings --> call --> All calls --> Auto reject. select "Reject list" thn uncheck to remove the number from the rejection list. Enjoy By REX T (Nagercoil)
Just goto
settings-->call settings-->all calls-->Auto reject
Make sure that it is 'on' for activation. Also click on 'reject list' and make sure the number you want to be in reject list is being checked with a check mark.
