Question about Alpine CDA-9847 CD Player
CD WON'T PLAY THE NUMBERS MOVE BUT NO SOUND AND THE TUNER HAS SOUND?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Alpine Master
  • 2,226 Answers
It sounds like you are using an amplifier. if so, make sure you are using the blue/white wire to turn the amp on instead of the blue wire. the blue wire is antenna remote and turns off when leaving tuner mode. the blue/white wire is amp remote.
Posted on Nov 01, 2010
6ya staff
SOURCE:
No sound when I play my CD on my Micro Hi-Fi System
you have cd output sound before or never you get sound from cd if you never get sound from CD then u call Service Center
May 21, 2012 | Audio Players & Recorders
Sound won't come on with the tuner
Hello
There ar two possibilites for thif fault, and both are related with its tuner circuit board. Either the tuner section do not get proper voltage to function, no tuning will be done or if the varactor diode that helps electronic tuning has got damaged. In both cases, no tunig will be done.
Feb 08, 2012 | Harman Kardon Audio Players & Recorders
My Apline CDA-9831 has no sound when trying to play regular store bought CD's. It dose have sound on Tuner.
Are you using an amplifier? If so, make sure you are using the blue/white wire (amplifier remote turn on) instead of the blue (power antenna remote turn on) to turn your amplifier on. The blue wire turns off when leaving tuner mode.
Jun 28, 2011 | Alpine CDA-9831 CD Player
The tuner works fine, all the speakers play including my sub. When I put in a cd, only my sub makes sound, and when I go to the ipod no sound comes out. However When I go to the zone control and select the...
are you using more than one amplifier? it sounds like you may be using the blue wire to turn one amp and and the blue/white to turn the other one on. use the blue/white only. the blue wire is antenna remote and turns off when not in tuner mode.
Jan 09, 2011 | Kenwood DDX516 Car Video Player
Vrv785bt- No sound except tuner
sounds like u have a premium sound system. what u need to do is take ur blue/white remotewire to ur blue power antennat that should activate ur factory amp.
Apr 16, 2009 | Clarion VRX785BT Car DVD Player
I am getting sounds only out of my tuner selection (radio) source
I would start off by doing exactly that removing the black box tuner out of the equation. The next question is did you install the black box or did you have someone else install it for you. If the box is not installed propperly then the audio outs could not be wired up correctly. Double check all of your connections. It could be something as simple as bad or no power to the box.
Mar 01, 2009 | Crossfire VR1000D Car Audio Amplifier
No Sound from CD but I do get sound from tuner
you have the blue, power antenna, wire hooked...
(blue/white is remote for amp)
Feb 20, 2009 | Alpine CDA-7863 CD Player
Tuner works but when i play a cd it shows that it is playing but no sound comes out this cd player is brand new
Take it back for a refund or replacement, If you have speaker output on the tuner,their is no reason or why it shouldn't give you tunes when you insert a CD.
Regards, Paul
Jun 12, 2008 | Kenwood Car Audio & Video
Tuner increments
those are odd numbers you decribed there
i understand what your saying to get the even numbers you have to use the remote and single click to what you want and if you want to stop a seek for frequencie hit the button back
you know foward select for scan and then back button for stop and then single press in what you need it takes a little fenness to control for even even numbers you just have to stop scan and seek single taps at a time
Jun 08, 2008 | Pioneer DEH-1900MP CD Player
Alpine CDA-9847 CD Player Logo
35 people viewed this question
Top Alpine Car Audio & Video Experts
Robert Salgado
Robert Salgado
Jeffrey Turcotte
Jeffrey Turcotte
Marvin
Marvin
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
