Unfortunately this type of coffee maker does not have serviceable parts. The manufacture does not recommend dis assembly of the products and does not off replacement parts. The problem is most likely the power switch or the small solid state circuit board inside the machine, that is not replaceable.
HI,
First,
do a motor test by removing the work bowl completely and using a pen to
press in the grey button on top of the base (with the food processor
turned on of course), toward the back. If the processor spins, the motor
is still good. At that point, I would inspect the work bowl pieces,
lid, pusher assembly, etc for cracks/damage. If all appears well, insert
ALL the pieces back into place and try again. If even one piece is out
of place, the processor will not spin.
If it no longer spins, the motor has a problem.You need to replace it.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
The solution provided was NOT for the correct item. The information provided was for the Cuisinart Food processor.
I requested a solution to a problem with the GRIND AND BREW COFFEE MAKER.
Please re-inform.
Thank you.
Maria
