Http://support.liftmaster.com/articles/How_To/LiftMaster-receiver-and-remote-compatibility-1484145638635
I don't believe a universal remote will work. Here is a link to compatibility
SOURCE: Grage door reverces and goes back up after touching the ground
ADJUST THE CLOSE LIMIT SWITCH UNTIL THE DOOR CLOSE SOFTLY, UN CAN DECREASE IT BY TURNING THE FLAT SCREW COUNTERCLOCKWISE.... VERIFY THAT BOTH LEDS OF THE PHOTOCELLS ARE ONE.. OTHERWISE U GONNA HAVE TO ALIGN THEN OR REPLACE IT!
SOURCE: Lift-Master garage door opener stopped working
The motor will probably need rewinding.
Professional job. Don't forget to take the condensor with the motor.
Or alternatively, if money isn't a problem,, get somebody out to look at it.
There ya go:)
SOURCE: Help, my Lift-Master garage door opens 2-3 ft
SOUND LIKE A BROKEN SPRING.
LOOK ABOVE THE DOOR IF THERE IS A GAP IN THE SPRING IT NEEDS TO BE REPLACED,
I DO NOT RECOMEND THIS AS A DIY JOB. THEY ARE UNDER MUCH TENSION AND CAN COST YOU FINGERS IF YOU DON'T KNOW WHATYOU ARE DOING - CALL A PRO
HOPE THIS HELPS
SOURCE: The motor makes a noise but seems locked up.
Make sure the door is running well with out the openers help first of all. If it is making this sound then look inside the unit with the unit unplugged for white shavings. If so you will need to replace the gears. Thanks BB
SOURCE: can i use a lift master remote that has dip
THE NEW OPENERS USE A DIFFERENT FREQUENCY - SO IT WON'T WORK.
SORRY
HOPE THIS HELPS
