1993 Honda Civic 4 Door Logo
Posted on Jun 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
OIL Quick question how much ml or liter of oil do i put in my civic
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 359 Answers
  • Posted on Jun 11, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
359
Questions
Helped
150694
Points
781
I think around 3.5 - 3.8liters not quite possitive but if its empty from an oil change that should be fine on level ground once you have filled it wait a minute then check the oil level on the dipstick you cant go wrong
A/c compressor need oil
PAG oil is best if its totally empty 40 ml will do
Oil change but oil continues to blink
Simple check first. Check your oil and make sure it is reading correctly on the dipstick. If it is low then add oil and watch everyday to see if the oil drops. If it is dropping quick enough to notice in a day or two then you have a leak somewhere an need to find that. A pressure test may need to be done as well to make sure oil pressure is high enough.
How many quarts of oil does a 2012 honda civic 1.8 liter take?
I have a 2012 Honda Civic sedan. In the manual it says 3.9 quarts. Th oil grade is 0W20
Can engine oil just disappear? Wll Kia seems to think so!
i have a dodge that does the same thing... when you find out let me know!!
I have civic with 1.3 16v engine.what is the best gear box oil,and how much liters do i need
There is no best gear box oil, only the correct gear oil.
Buy it from Honda and the parts guy will tell how much
you will need. I assume you have a manual transmission
so fill it till it's level with the fill hole. This is just a guess,
about 2 liters.
2answers
I bought a used Honda Civic Hatchback 2001, code EU1-1020777. When purchased, I put 1 liter of transmission oil, but it was not CVT recommended oil. Several other people had major problems with...
please specify what your problem is.
your vehicle is not equipped with a cvt transmission, so does not require cvt fluid. adding cvt fluid would cause a catastrophic failure. please reply and explain what problem you are actually experiencing.
1helpful
Liters of oil in 2000 honda civic ex
3.7 quarts, not liters. Good luck and thanks for rating my response!
What would make the crankcase on a 1999 Honda Civic LX pressurize, it has oil vapor shooting out of the dip stick tube & is pushing oil out of the front & rear main oil seals? The car starts fine,...
I saw this once where a guy took his car to one of those Quick Oilchange places and the kid put in new oil and forgot to take the old out first. Another thing to check is youre PCV Valve, if this is blocked it will increase your crank case pressure.
High fuel consumption , even after changin plugs/filter/Eng.oil/cvt gear oil and cleaning the throtle
Checked brakes for possible wheel(s) dragging, as well as tire pressures up to max recommended pressure, and observe if tire wear unusual, signifying improper alignment? Any difference in engine oil grade used?
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
