Question about RCA S1000 MP3 Player
Lo que pasa que ya no tiene ninguna carpeta para meter musica y las estaciones de radio ya no cambian
Posted by betomm_13 on
5 Related Answers
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: mp3 no lo lee mi compu
Firmware upgrade needed - RCA website - select "Spanish" for language
Posted on May 24, 2008
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: la musica se corre
Make sure the songs are in the correct format. Make sure the songs are not AAC, WAV, streaming, or some other non-supported format
Mp3 players are more complicated than ever. This player may only accept DRM-encrypted WMA files. I would first check the songs that you have downloaded to make sure they did not have "temporary" licenses with a fixed end date. You can do this by right clicking on an individual song, clicking on properties, and selecting the "license," "digital rights mgmt" or "media usage rights" tab - the wording varies by configuration. It will give you info on the license. If the song says that it has no license, it will not work with this player. One remedy is to use mp3 converter software to convert all of those wma files to Mp3's - I don't know of any free ones, but you can certainly look for free Mp3 Converters. Another remedy on unlicensed songs is to hit the "acquire license" link in the license tab, if one exists.
-Tha Mp3 Doctor
Anonymous
SOURCE: Informacion
por favor necesito codificar control remoto modelo rcr412si1612p para el televisor rca f27242gy
Posted on Jul 05, 2008
Anonymous
  • 230 Answers
SOURCE: tengo un tv que tiene la falla en la convergencia de colores
Hola, gracias por visitatar fix ya.
Mira, tienes un fusible abierto, que no te permite entrar a los ajustes.
A un lado del fly back hay tres pastillitas colo cafe ( fusibles), el de enmedio es el que tienes que cambiar (400ma), pero tienes que resoldar toda el area del fly back, por que ahi tienes falsos o loose connections.
Si tienes alguna pregunta, aqui estare.
Gracias.
Posted on Jul 26, 2009
Anonymous
SOURCE: rca contro remote
esto tratando de programar un rca control remoto para un televisor sharp y no puedo no se que pasa me ayudan por favor rcr312w
Posted on Oct 04, 2009
2answers
Como instalar windows 7
Amigos, si no le importa gastar un poco de dinero para actualizar a Windows 7 se puede tratar este enlace: http://instalarclave.blogspot.kr/. La clave funciona al 100% y su precio es barato. M?s importante a?n, usted no tiene ninguna necesidad de preocuparse por el riesgo de virus.
Diagrama de encendido ford ranger 2002 3.0 v6 2wd
losiento amigo pere esta marca de coche no existe en espana ,algunos si por el hydroelectra pere yo tienes ninguno experiancia con uno de gasolina ,esta tonto jiddy pinthando mejor pregunta con una chaputhero de mechanico local .Possiblymente utilithado el ECU mas chip e transponder de la vehcula donante
3helpful
2answers
Quiero pasar unas fotos de mi celular al pc lo intente en muchos pc y no pasa las fotos me pregunta si quiere que busque el software, al finel me dice que no lo encuentra nose que hacer.
si usted tiene la opci?n de "ver archivos y carpetas"o algo similar, trate deeso.
y luego copiarlas a una carpeta en el equipo
Estoy utilizando el traductor de google as? que perdonarme si no entiende
5helpful
2answers
No funciona solo aparece ecipse y es todo
A mí me pasa lo mismo y lamentablemente nadie aporta una solución, el mío (Eclipse 180 8GB)se ha quedado trabado en la pantalla azul de inicio con el logo "Eclipse" y no sé que hacer. Un tipo en las respuestas en idioma inglés dice que llamó al número de atención al cliente y le dijeron que dejara que la batería descargara por completo y luego presionara por unos 30 segundos el botón "Play" (me imagino que es el botón del centro, supuestamente es la manera de resetear el player) antes de conectar el USB al PC. No sé si funciona. Mi problema empezó por una canción que no tocaba bien y reinicié el aparato, y puse de nuevo la misma canción y luego se puso el logo azul en la pantalla y éste no se quitaba a menos de mover el switch a OFF, lo pase nuevamente a ON para que descargara por completo, pero ya no lo reconoce la PC y pide drivers, se queda congelado en el logo, ni carga, ni nada.
He visto que muchas personas tienen el mismo problema y todavía no aparece ninguna solución, tú post es el primero que leo en español. Dicen que será un problema de firmware, pero no venía con un CD de drivers o una herramienta para estos casos, la empresa Mach Speed parece que todavía no tiene una página de soporte implementada para este modelo "Eclipse", también no sé como destaparlo, pues la tapa es una sola pieza. Si sabes como solucionar tu problema, házmelo saber por este medio. Talvez es de esperar, porque el firmware que tiene mi player era de septiembre del año pasado y lo compré en noviembre, el precio es bajo, pero no es posible que nos tomen el pelo de esta manera.
1helpful
Quiero abrir reproducion de musica y dice error
Estimado amigo, Usted debe ser eliminado de la Música / carpeta que contiene las canciones que están tratando de juego tienen Mobile.So Rescan Recolección / Actualización de la música en la memoria del teléfono / MMC.Try este nuevo después Convierte tu Phone.Just Restaurar teléfono (sin borrar los datos el móvil ).... Todavía hay problemas
  • Formato de MMC en el teléfono (Todos los datos se perderán)
  • Teléfono-Configuración de formato> desplácese hacia abajo para Restaurar> Restaurar todos (todos los datos serán eliminados, incluidos los contactos Phone.So que necesita para copia de seguridad a la memoria SIM)
  • Copiar a la carpeta de música como música, sonidos, canciones, Digital (ahora esta carpeta ya estará en su tarjeta MMC)
  • Inserte MMC para Teléfono
  • Abrir el reproductor de música
Ahora ya está listo para usar .. Votos Me gusta saber .. Si esto te ayudó, ¿califico ... Espero que esto ayudó ..
Gracias por utilizar FixYa
7helpful
3answers
MI CADILLAC CATERA 98 PASA ACEITE A EL DEPOSITO DE ANTICONGELANTE Y EL CARRO CEMECALIENTA Y SE APAGA QUE DEBO DE ACE CAMBIA EL MOTO O Q
El problema está en el enfriador de aceite, que va instalado el el bloque del motor, justo en medio de las cabezas.
Cambiando el enfriador de aceite se resulve el problema. El # de parte es 93176626 y lo puedes comprar en www.rockauto.com el precio es de USD 235
8helpful
MI CADILLAC CATERA 99 PASA ACEITE A EL DEPOSITO DE ANTICONGELANTE
tu problema no eran las cabezas sino un enfriador de aceite que se esncuentra en medio del motor por debajo del multiple de admision lo puedes identificar por las dos lineas gruesas que se le conectan, su funcion es enfriar el aceite del motor pero hay defecto de fabrica y la agencia te repone el motor gratuitamente o puedes comprar la refaccionen la agencia la cual viene perfeccionada por el precio de 350dll
1helpful
2004 dogde intrepid SE.
ok si quieres cambiar tus amortigadores frontales lo que tienes que hacer es quitar tus ruedas, zafar la horquilla de la base del amortiguador, luego con un opresor de resortes ponlos en el resortes y comprime los resortes, quita la base de arriba del amortiguador, quitalo de los 2 tornillos de abajo y con cuidado saca el amortiguador.
realiza la misma operacion con el otro, para montarlo lo unico que debes de tener cuidado es en que el opresor sea lo sufucientemente chico para que entre en la cavidad de la llanta y lo suficientemente grande para que oprima el resorte
primero pon el opresor, las gomas, y dirigelo para que entre en la parte de arriba, luego atornillalo arriba y luego abajo, quitas luego el opresor de resortes.
tengo el manual del intrepid ya te deje mi correo en otro mensaje.
saludos.
PD del compresor me imagino que te refieres al AC lo que pasa es que probablemente no tiene carga o no recibe voltaje si no se activa el compresor es por que tienen un sistema de seguridad en el cual si no tiene carga de gas no trabaja !
La imagen no se ve .. el display tiene luz . el sonido anda bien
Hola ... Buen dia ...
He recibido el correo ...
Bueno, el problema aun existe ... he revisado las tensiones de fuente , por lo que pude ver hasta donde pude, ya que no tengo ningun manual , es solo lo que vi , todas estan presentes ... tambien revise los reguladores de tencion de la placa que esta hubicada en el medio a la derecha de la fuente . y estan bien ... para forma de ver la principal sospechosa de la falla , por que el sonido y sintonia estan bien .. la iluminacion de la pantalla tambien . y no tengo nada de nada de imagen en ninguna condicion ..
EL ofrfecimiento que me hacen seria interesante ... pero no poseo cuenta bancaria , no targeta de credito para efectuar el pago ... por eso no me asocie ... mi momento economico es duro ...
Lo que venia arreglando este ultimo tiempo son MINILABS que hacen las fotografias. pero la enorme rececion den Argentina daño mucho ese mercado .. En la T V LCD, es la primera vez que incurro ...
Quedo agradecido por la atencion y en espera de vuestro comentario ..
Preset channels
Para que las estaciones se queden en la memoria del estereo este tiene un cable amarillo que debe conectarse a la corriente directa si no lo conectaste asi nunca van a memorizarse,para poner las memorias sintoniza la estacion que vas a memorizar despues manten presionada la tecla de memoria donde la vas a almacenar( 1,2,3,4,5,6 ) por 5segundos hasta que deje de parpadear despues sigue con la siguiente.
RCA S1000 MP3 Player Logo
Top RCA Audio Players & Recorders Experts
Jean Sintulaire
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
