Question about GE Energy Star WCVH6260F Front Load Washer
Door lock light is on and can't get through another cycle. I even unplugged my front load washer. After 5 minutes, I plugged the outlet in and hit the power button. Now, the cycle is stopping so often, there is no spin, and just hear noise from the clothes washer. What is wrong with my GE Model # WCVH6360FWW, front-loader clothes washer? Please help.
Posted by jemj_2000 on
Chris Huff
    Top Expert:
  • GE Master
  • 6,289 Answers
I would take filter out of drain Pump and check for obstructions. There will be water gushing out when filter is removed, so be prepared.
Posted on Sep 29, 2017
5 Related Answers
Anonymous
  • 641 Answers
SOURCE: GE Front Loader Washer - Not washing
It sound like a lid switch issue. If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Look that the switch is not broken or loose. If all is fine, you should replace the switch. Good luck!
Posted on Aug 27, 2007
Anonymous
SOURCE: GE Washer stuck on final spin cycle
My GE Prodigy just did the same thing the other day and I just unplugged it and plugged it back in and so far so good.
Posted on Apr 08, 2008
Anonymous
  • 5 Answers
SOURCE: GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Posted on Oct 31, 2008
Charles Caldwell
  • 66 Answers
SOURCE: ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Posted on Nov 27, 2008
Anonymous
SOURCE: GE Front Loader Won't complete cycle
My GE Front Loader is 18M old and it has been progressively getting worse, not spinning the water out......I should have known the Pump had a cleanable strainer as Solution #1 says. Pulled a fist size chunk of wet lint, coins, a necklace and wrappers from the Strainer, not to mention about 2 Gal of dingy, soapy water. Tried a Drain/Spin and after a couple of minutes, went to High Speed Spin for the 1st time in about 3 months. Obviously there is a Water Sensor on the Drain Line somewhere that if the Drain Line still has water in it, it does not allow washer to go into Med/High Spin Mode.
Posted on Feb 17, 2009
Frigidaire Front Load Washer wont start!
sounds like you have a very unhappy control panel..unplug it, wait 5 min..and then plug it back in..if it does not reset, then you may want a repair job, no?
Apr 30, 2008 | Frigidaire ATF6000ES Front Load Washer
How do I unlock a whirlpool duet washer
from a previous discussion:
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
Jan 04, 2015 | Whirlpool Washing Machines
LG WM3431 door won't unlock
did you unplug it,leave it unplugged for 5 minutes and plug it back in,if it's to hard to get to plug flip the breaker and leave the power off for 5 minutes or longer when you power it up again the door should unlock.here's a link to check hope it helps
https://www.google.com/search?q=lg+front+load+washer+how+to+manually+open+a+locked+door&oq=lg+front+load+washer+how+to+manually+open+a+locked+door&aqs=chrome..69i57.21935j0j8&sourceid=chrome&ie=UTF-8#kpvalbx=1
Dec 29, 2017 | LG WM3431 Front Load Washer / Dryer
My washer door is locked and how do i get it unlocked. the light is on and will not go off even after i ran thru a cycle.
unplug your washer for 5 minutes cut it on and see if you can unlock door, buy you a new door lock switch
Sep 24, 2009 | Maytag MAH6500 Neptune Front Loading...
Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
Apr 09, 2009 | Whirlpool WFC7500VW Washer
The control locked light is on and can't start the machine
Power shd be on, try to hold down 'end of cycle' button for 3 seconds, try door after a minute or after hearing a click. IF NOT:
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about 1/4 inch or until a click is heard.
6. The door may now be opened.
Apr 06, 2009 | Kenmore Elite 45986 Front Load Washer
Unable to cancel cycle and restart machine
Instead of hitting cancel twice, only press once,. You should hear the washer unlock. Then try to start again. If that doesn't work, try unplugging the washer in mid cycle. Are you getting and codes popping up?
Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
Maytag neptune model# mah5500b
Unplug from the outlet and wait about 5-10 minutes. When you put the plug back into the outlet, the door should unlock.
Aug 23, 2008 | Maytag MAH6700AWW Neptune Front-Load...
GE Energy Star WCVH6260F Front Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
