Question about Belkin (F5D7230-4) Router (587009)
I was connected wirelessly to my belkin router and then i clicked into manual set up mode and it came up with a website showing all my IP address details and settings. I clicked on LAN settings and desabled the DHCP server and I lost internet connection. I then plugged my ethernet cable from my computer directly into the router hoping this would give me internet access and i could go back into my router settings on line and enable the DCHP server but it wouldn't let me connect. I tried it on another computer and its as if I'm locked out. I've tried resetting the router but the reset button doesn't seem to work. Not really sure what to do now. HOpe you can help. Thanks. Alison
Posted by cosmic_venus on
  • Belkin Master
  • 7,733 Answers
Go to Belkin : Support : Setup Assistant for Routers
,if you need more help, post or thumbs back.
Posted on Oct 31, 2010
Im trying to set this up as an access point. but it will not fine a ip from the router
Most router wont act as a DHCP client (Get an IP address) on their own.
You need to go into the Belkin setup and set it to an IP address in the range of your other router.
For example:
If your PC is getting (connected to the same network) an IP address of 192.168.0.3 IP and a Default Gateway address of 192.168.0.1 you can set the Belkin with any adderss between 192.168.0.10 & 192.168.0.254. Changing the last octet (set of numbers after the 3rd period) to the desired address.
Mar 02, 2011 | Belkin Wireless-N Wireless Router with...
I have a embarq 660 series router and using a compaq presario computer. I have already installed the belkin surf/share wireless USB adapter to this laptop. When I go to Internet explorer it says offline.
your problem is a IP address conflict
Embarq and Belkin have the same IP address 192.168.2.1
change the IP address in to your Router.
To restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on the bottom of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
======================= Manually configuration ==============================
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Now go to lan settings and change the IP address 192.168.2.1 in to 192.168.1.2
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
=================== WIRELESS SETTING UP A WIRELESS CONNECTION ====================
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Sep 06, 2010 | Belkin Surf Share Wireless USB Adapters...
My son's new Xbox Live cannot / will not connect with our wireless router, even though it recognizes it. I have a Belkin 802.11b
1) Get connected to belkin's wireless network or wired network
2) Once you get connected, it may not be able to go online on XBox Live
3) Go to any computer that is going online with the router
4) Type in 192.168.2.1 in the address bar of your Internet explorer
5) This will open up router interface(here we have to do some settings)
6) In the left hand side column, click on FIREWALL.
7) Leave the password blank in login page and disable the FIREWALL. Click on Apply Changes.
8) Under FIREWALL(in the left hand side column), click on DMZ
9) Make a "check" on enable and under Private IP: 192.168.2.25. Click on Apply Changes.
10) Now go to Xbox, under network settings, choose IP settings, and select manual configuration
IP: 192.168.2.25
Subnet: 255.255.255.0
Router: 192.168.2.1
11) Now select manual configuration for DNS settings.
Primary DNS: 4.2.2.2
Secondary DNS: 4.2.2.1
12) Restart both Belkin and Xbox
13) It should connect to XBox Live now...
Jan 17, 2010 | Belkin (F5D8231-4) Wireless Router...
Belkin54g default gateway problems and connecting to router page
reset your Router via pin whole at its back then set the config of TCP/4 and obtain Ip automaticaly and obtain DNS automaticaly... later set your settings according by 192.168.1.2 without changing IP and then turn off you router ... turn it on after 5 to 10 min .. thank you
Jun 24, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Defualt gateway problems with belkin54g cannot connect
1. Click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections.
2. Right-click the network connection that you want to configure, and then click Properties.
3. On the General tab (for a local area connection), or the Networking tab (for all other connections), click Internet Protocol (TCP/IP), and then click Properties.
  1. Check the option which says use the following ip address and enter the ip address that you have forced in the belkin router, type the subnet mask 255.255.255.0 and enter the default gate way the ip address of the belkin router (ip address that you use to open Belkins page)
Jun 23, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
I have a Belkin Wireless adaptor and a wireless router. The netgear adaptor I had before on my desktop got borken so I replaced with a Belkin adaptor. The new Belkin adaptor is not recognizing the wireless...
Hi, did you provide the network key/password when you setup the wireless conection on your computer? Is it detecting your wireless router (you should see your SSID or network name) when you click on your wireless icon (in the taskbar) and chose "show wireless connections". If you can acess to your router via it's configuration page(type the router's default IP address in your browser) you can go check the settings and change the key/passphrase if you dont remember it. If all of this is not working, you can also start from stratch. Reset the router to factory settings (check your manual) then reconfigure it the way you want, put the new infos in your wireless network connections properties and try again. let me know with more specific details if you still cant do it
Jun 08, 2009 | Belkin Wireless Desktop (F5D7000FR)...
Belkin Wireless connection speed at 11mpbs. Why not 54mpbs?
this is from the d-link support page:
"Question :Why can't I get the advertised speed and performance when in Ad-Hoc mode?
Answer :
This FAQ applies to 802.11b, 802.11g, and Super G™products.
D-Link wireless products follow the IEEE 802.11 standards. The802.11b and 802.11g standards specify that Ad-Hoc mode only needsto support up to 11Mbps. For best results, use an access point orwireless router and set your adapters to Infrastructure (station)mode."
Feb 03, 2009 | Belkin (F5D7000) 802.11g/b Wireless...
Belkin
Yes there is just follow the following:
To setup your Belkin Router please follow the steps below.
Once the router is connected, check if your PC is communicating with the router. On the desktop click on Start and then on Run. In the open box, type cmd.
It will bring up the command prompt window.
Type the command ipconfig in that window and press the Enter / Return key on the keyboard. It will bring up results similar to the image below
Note the values of IP Address and Default Gateway in the ipconfig command results. If the IP address is in the range of 169. 254.x.x or 0.0.0.0, then the PC is not communicating with the router. In this case contact your router vendor for support.
If the IP Address is in the range of 192.168.x.x then the network setup should be ok. Note the values of IP Address and Default Gateway. Close the command prompt window. The default gate way for belkin is 192.168.2.1
Open Internet Explorer window and in the address bar type in the address that you found for Default Gateway. In case of Belkin router it should be 192.168.2.1. Then click on the Go button.
It should bring up a screen similar to the image below. Refer the product manual for the default Router password. In case of most Belkin routers, it is blank. So, just click on the Login button.
This should bring up the Belkin Router Setup Utility. Click on the Wizard link on the top bar of this page. In the Connection type options, select PPPoA. Then click on Next button to continue. Notice that on the top right side of the page, it says "No Connection". Once the setup wizard is complete, it should change to "Connected"
In the next window that appears, enter the broadband email address and password in the respective boxes. Then confirm the password in the Retype Password box. In case of VPI/VCI:, type 0 and 38 in the left and the right boxes respectively. Then click on Next to continue.
Click on the Apply button to save the settings.
It may take up to 5 minutes to save and update the settings. Once completed, you will see, "Connected" on the top right side of the window. Once you see that close this window and open your browser window to go to any website.
May 17, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Program for belkin router
you don't require the disk...
co0nnect your belkin router with ethernet cable into the comp...
open internet explorer type an address as 192.168.2.1 it will take you to router config page..it will ask for a password leave it blank
click submit
click the Wizard link on the top menu bar.
For a UK ADSL connection, you will need to select PPPoA (Routing mode, for multiple PCs) even if you are only going to connect a single computer, then click the next button.
The next step is to enter your username and password that your service provider has provided you with. To try and ensure the password is entered correctly it must be entered twice. The VPI/VCI values of 0/38 are the correct ones for a BT Wholesale ADSL line. If you are using another telephone provider check the settings required. Click next again to continue to the next phase in the wizard.
This screen tells you what your Internet IP address is (the WAN IP), and you will note that the menu bar at the top of the page now shows the Internet Status as connected. For the review, there is really one bit of configuration left to do. During the course of reviewing hardware we tend to swap kit in and out several times, we generally prefer to run the routers on the same IP address (192.168.0.1). This is easily accomplished by clicking the LAN Settings link on the left hand menu of the Belkins web setup and altering the routers IP address.
The router is clever enough to alter the DHCP server IP ranges to match the new LAN IP address of the router. Once the changes were applied it took around a minute for the router to restart, during which time the wireless signal dropped, but once this reconnected the PC was assigned an IP address in the new range of 192.168.0.x.
Feb 16, 2008 | Belkin (F5D7000) 802.11g/b Wireless...
Belkin (F5D7230-4) Router (587009) Logo
Top Belkin Computers & Internet Experts
Mike
Michael Thomas
Michael Thomas
Lee Hodgson
Lee Hodgson
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
