Question about GE GSH22JFR Side by Side Refrigerator
Can this GE TFX side by side be used as an extra frig in a garage that gets very hot in summer
Posted by mikecov on
geoff hunter
  • 4,793 Answers
Most (not all) f/f can be used in ambient temps from about +5C to +35C,but use a seperate thermometer to keep the interior temps at +5C for a fridge and -18C for a freezer.
Posted on Oct 31, 2010
I have a ge refig side by side the # is 62D581P016 the door frame where the gaskets are located gets hot to the touch. We have cleaned the back under the frig and the fan is running, however, it is st
Most modern refrigerators have heaters around the gasket to keep frost and condensation from forming. What you're seeing may be normal.
Sep 09, 2014 | Refrigerators
Have extra older Frig in th garage Mod 596.72232200
Sounds like a intermittent problem with the defrost timer. Sometimes they get stuck. Check continuity of the defrost heater and defrost thermostat. If both are good then replace the defrost timer, that should solve the problem.
May 30, 2014 | Refrigerators
Owners manual for GE TFX 24 R
the lower hinge on the frig side is broken and you have to physical push the door close. would you know a part number. look like plastic thanks
Dec 20, 2011 | GE GSH22JFR Side by Side Refrigerator
Refrigerator/Freezer not getting cold
Is the fan on the condenser coils spinning? (back side of unit behind the bottom access panel.)
If it is not, the heat extracted from the fresh food/freezer compartments is not being sufficiently dissipated.
As a short-term fix, you can aim a box fan (a regular ol' room/window fan) at the condenser coils.
Jul 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frig not very cold & metal between freezer and frig gets hot
Poor cooling and a hot divider mean that air is not moving effectively over the condenser coils under the fridge. Check to see if the fan is blowing under there while the compressor is running. If not, then the condenser fan has failed and needs to be replaced. If it is, then use a vacuum with a long nozzle to give it a good cleaning under there.
Jul 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH22JFR Side by Side Refrigerator Logo
115 people viewed this question
Top Refrigerators Experts
Vish Iyer
Vish Iyer
gbob59
