HP iPAQ HX4700 Pocket PC Logo
Question about HP iPAQ HX4700 Pocket PC
IPaq 4700 stuck on 'align screen'
Posted by marget27 on
5 Related Answers
Mike McWhinney
  • 537 Answers
SOURCE: Ipaq RX 3115 Stops at align Screen
solia, I'm sorry, I didn't mean to close the chat session on you.
Is your unit still under warranty? If so, check with the manufacturer.
They can help.
Mike
Posted on Dec 03, 2007
SOURCE: stuck on "align screen"
your touch screen gone just change your touch screen it goes back to normal
Posted on Mar 20, 2008
Anonymous
SOURCE: Hp 4700 ipaq does not display properly
Take a firmware update to your Hp 4700
Posted on Mar 26, 2009
Anonymous
SOURCE: Align screen on IPAQ
Tap the target firmly and accurately at each location on the screen.The target will continue to move until the screen is aligned,
pls help.what can i do.
Posted on Nov 18, 2009
SOURCE: CANT ALIGN SCREEN AFTER A HARD REBOOT OF MY IPAQ
you need to replace touch screen
Posted on Dec 15, 2009
2answers
Stuck on "align screen" How I align screen H6300 Ipaq
hi friend...
try an HARD format,,,that will solve it sure.....
thank u ../////
PLEASE RATE IT
14helpful
My pda hp 4700 won't turn on. It's about 3 years old
Assuming that the switches on the bottom case are in the correct position. Try reflashing with original HP rom:
http://wm6.winmobile.us/hpmain.htm
IPAQ 4700 hard resetting on its own.
I also own an ipaq 4700 and experienced the same problem. Even after reloading the OS I continued to have this problem. I did buy it refurbished but I fear this may be a common hardware problem. From my research it would appear the battery is the most likely culprit, I have not tried replacing mine but it may be worth a shot, if nothing else you have an extra battery which means less time at the charger :D
Printed manuals and CDROM for HP Ipaq 4700
I found the right place to post this request so I have transferred it.
3answers
They can help.
Mike
4700 photos no longer scrolling on screen saver
you may want to change the time after which the IPAQ turns itself off. If this time is too short, then Dockware may not be activated.
Top HP Computers & Internet Experts
Marvin
Marvin
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
