SOURCE: problem with sanyo tv
OK this is just strange but - I have a remote for a RCA Digital to Analog box and if I hit the 'input' key a couple of times it seems to clear the number from the screen. Can't find any place to do this in the standard menu - and the original remote is long gone..... Likely as not there is a remote with a button doing strange things just like this,
SOURCE: fridge & freezer not cooling. Meat thawing
If the refrigerator isn't cool, you need to answer
some questions, then see if the compressor is running.
First, answer these questions:
Is the refrigerator completely dead? If so, see “It's
stopped completely.”
Is the thermostat knob turned to the proper setting?
If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no
apparent moving parts. It's on the outside of the refrigerator at the
back near the bottom. If it is humming or making a continuous noise and
your refrigerator is still not cooling, there may be a more serious
problem with one or more of several different components, we recommend
contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have
power to the refrigerator, there may be a problem with one or more of
these:
The compressor
The Thermostat
The overload, relay, or capacitor
The defrost timer
The condenser fan motor
SOURCE: We have a Sanyo tv with an 03 in the upper right
that is not the recall button to command it.try the OSD button or the DISPLAY button...and it should be gone!
SOURCE: i have a 47 inch sanyo lcd tv and the screen is
i have a 47" inch lcd sanyo t.v. and my kids accidentally shot it with an air-soft gun. and there is a crack where the pellet hit and there is also a crack running down that spot. Also the screen has these lines running up and down the screen. Different colors. and i was wondering if it was possible to fix.
