Press & hold the power button > unplug the power cable from the back of the printer while holding the button for 30 seconds > plug the cable back then release the button. A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
Refer to my cure for error 0xc19a0035 My machine was doing all sorts of stupid things, different error messages, power looping at switch on, paper getting jammed, cracking and grinding because the print head motor was trying to drive the head through the side of the machine and all caused by a faulty capacitor in the internal power supply on the systems control printed circuit board.
I hope this is some help to you all with various faults on what is a superb machine when it is working ok.
Robert t
Thank you sooo much! Your fix worked for my printer. Since the best source for parts nearby was Radio Shack, I had to settle for a 470mf / 35volt cap. I figured I had nothing to lose. That size seems to work so far. Thanks again and Happy Holidays!
Conrad
Hi Conrad,
Glad info was useful and the cap you've fitted will be fine..Better for it to be on top of it's work than not. I wonder how many of these machines have been thrown out needlessly. It was all the different stupid display messages that made me think, this is an electronic fault and not mechanical.
Anyway all's well that ends well and I wish you merry christmas and a happy new year from all in the UK.
Regards,
Robert.
SOURCE: error: 0xc19a0021 Ink system failure
These errors that always come out starting with 0xc.. - only means that there are internal error inside the printer.
These errors can only be remove if you reset the printer.
here's the step to reset your printer
1. While your printer is on.. disconnect the usb cable from the back of your printer.
2. Remove the cartridges.
3. Wait until the message "Insert Cartridge" display on the control panel.
4. Disconnect the power cord from the back of the printer.
5. Wait for 60 seconds.
6. Plug the power cord at the back of the printer...If printer does not automatically on..press the "Power" button.
7. Reinsert the cartridge and close any open doors of the printer.
8. If prompted to Calibrate, do so..
9. Reconnect the usb at back of the printer...and try printing again..
Hope that solve your problem..
Much appreciated if you rate this help..thanks..
