Question about Adidas Wooster ADH1768 Watch
I can not change the time on my watch ADH1768. I can not find your model in the manual to help me on settings. Thank you! Vanessa
Posted by ne_freitas on
David Tolond
    President:
  • 2,501 Answers
It appears that this model has been discontinued so that it will not be in their catalogue.
The instruction manual list for Adidas does not list them under models but as descriptions of features.
If you go to http://www.adidas.com/campaigns/watches_fw07/content/performance/pdf/performance_en.pdf and scroll down to the one called "10 lap digital", this seems nearest to the model you have.
Try following the "time setting " instructions. There may be slight differences between models but there a limited number of alternative button sequences available, so it shouldn't take very long to work out the correct alternative if the one given is not quite correct.
Posted on Oct 31, 2010
How do I set the analog time on my Casio illuminator watch
Every model changes the way time is set , the watch should of come with a manual, If not Google ( Casio watch manuals) then in the search window type in the watch model, click search, then down load it.
Mar 03, 2016 | Casio Watches
Can't set time on adidas 1768 watch
on the lower right button of your watch is the set button, you have to press and hold it. and in the lower left is the mode button is the mode press it to choose whether you are about to change the flashing digits. the upper right button is start/adv. it is use for adjustment of the flashing digits. i hope this will help you.
Jul 27, 2011 | Adidas Wooster ADH1768 Watch
Dont know how to set the time for adh1768 women watch
many kinds of watches in the site,hopes it could help you
Jun 04, 2011 | Adidas Watches
I accidentaly reset time & date on my square arnette watch and i need help to set it
Thank you for contacting FixYa.
    Set Digital Watch
  1. Press and hold the "Mode" button on the right side of your Arnette digital watch for three seconds to change the watch's mode. Press and hold the "Mode" button repeatedly until flashing digits indicate that you have entered the watch's time-setting screen.
  2. Use the top and bottom buttons on the left side of your Arnette digital watch to increase and decrease number values as desired.
  3. Press and hold the "Mode" button repeatedly to exit the time-setting screen and return the watch to time-telling mode.
  4. Set Analog Watch
  5. Pull out the watch crown on the right side of your Arnette analog watch.
  6. Turn the watch crown clockwise to adjust the hands of your Arnette analog watch to the appropriate time.
  7. Push the watch crown back in when you are finished setting the time on your Arnette analog watch.
Best regards. Jewel
Sep 09, 2010 | Watches
Have a casio g-shock GS-300. Need to turn off the hourly signal (the beep). Grateful for solution
I have a Casio GS-300 watch. I need to change the batteries, but cannot figure out how to get the back off. Do you have any ideas as to how I can do this.
Thank you Vanessa
Jun 11, 2010 | Casio Watches
Need to reset the time on the Nike Wk6000 watch can't seem to get it to change Help! Thank you!
I assume that you haven't got your manual.
You can get one by going to "http://www.nike.com/timing/". Select "support" and on the left side of the page is a box headed "find manual for your model"
Click on the arrow and select "running" and then select your model from the list.
Download instruictions
Mar 19, 2010 | Nike Triax WK0006-001 Watch
How to set the time on an addidas wooster watch
Put "adidas watches" into your search engine and select the Adidas.com site.
On the screen you will see a menu, select "instructions" and look for your watch in the list of illustrations that are there.
Jan 13, 2010 | Adidas Wooster ADH1768 Watch
Setting my watch
Hi go to www.casio.com/support under technical support choose manuals.
Nov 14, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Casio baby G watch model 3786 (can't change digital time)
Im a watch technician,and when im make adjustment to a new watch for me i dont need any manual,the thing ive done is keep pushing and pressing the button and observed what happen and the result i write what im discover new to me.When setting a baby g watch find the set and press it for 10 seconds.then your watch will flashing then go to mode button and choose what you are going to set.The hour ,the date ,the alarm whatever is there to set desame you going to do , only the set button need along press.Message me whatever you discover .
Jun 18, 2008 | Casio Baby-G BG370S-4V Wrist Watch
Setting time on Watch
go to this website follow the instructions for finding your particular watch module located on the back of your watch and enter it in the space provided. This will lead you to a place where you can download your manual and learn how to set your particular watch. here is the link to follow and please leave feed back if it was helpful. http://world.casio.com/wat/download/en/manual/
Jan 29, 2008 | Casio G-Shock G7100D-1V Wrist Watch
Adidas Wooster ADH1768 Watch Logo
467 people viewed this question
Top Adidas Watches Experts
Bruce Robin
Lisa Christine
Lisa Christine
Bill Boyd
Are you an Adidas Watch Expert? Answer questions, earn points and help others
