Question about Neovo AG 17" LCD Monitor
Neovo S-19 monitor wont turn on, only blinking green light
Posted by thomas_truby on
5 Related Answers
ginko
Ginko
  • 19396 Answers
SOURCE: The blinking green light on VX922
If there is a flashing led on front of the monitor, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1 The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours, sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr suddenly are a blown capacitor on power board, the inverter board powering up backlight lamp has blown, or a fault on main lcd controller board.
check also the video cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact Viewsonic to find out a Viewsonic service point.
See:ViewSonic - Support & Service
If you want to repair at your own expenses, just locate any good qualified repairer.
Regards
Posted on Mar 06, 2009
Anonymous
  • 149 Answers
SOURCE: Monitor wont turn on green light blinks but makes a clicking noise
hi there, light blinks constanly means a shorted electronics parts, most of it are in the horizontal sec., and power supply. check first the power supply if you have a constant voltage output, else your prob . is in the horizontal section. do somr test and check up. ty
Posted on Feb 18, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: F-17 neovo monitor stopped working. power light is flashing yellow
Regards
mavreix
Dillion Whitney
  • 63 Answers
SOURCE: My Neovo f-417 LCD Monitor is switching off after
This means there is a hardware failure in the monitor that could be either blown CAPs or a shorted out inverter. It is difficult and dangerous to replace both of those(involving soldering and desoldering) if you don't know how as LCD's are made of a hazardous material. I would try new cables and on a different computer as a last resort and if that doesnt work then your monitor is trashed. If it works on another computer then the issue is not with your monitor. Good luck!
Posted on Sep 23, 2009
Anonymous
  • 5 Answers
SOURCE: my hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Posted on Jan 13, 2010
I have a Neovo !( inch monitor used as a security
First place to look will be for bad caps in the power supply/inverter section, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 21, 2010 | Neovo E-19 (Black) 19 inch LCD Monitor
Apex Digital 19" LCD wont turn on green light blinks
you can have a electronics repair done on this unit call 719 687 6997
Jan 14, 2009 | Apex Digital AVL2076 20 in. EDTV-Ready LCD...
Neovo e-19a flat panel will not work with gateway e4000.
You may have to turn on the external video from inside the BIOS; not all systems are set up to feed video to the VGA port unless told to do so.
Oct 26, 2008 | Neovo E-19A 19" LCD Monitor
Will not turn off
check energy settings in manual or on pc
Aug 12, 2008 | Neovo F-419 19" LCD Monitor
Blackouts
have you checked your ram
Apr 03, 2008 | Neovo E-19A 19" LCD Monitor
NO PICTURE
Bad power supply. The light is green when it is not plugged into the monitor because there is no load on the power supply. When you plug it in the monitor tries to draw current, nothing the PSU can handle now, so the light blinks. The PSU can not provide the amps that the monitor needs.
Get a new power supply, you can find them on ebay. Just make sure the voltage and amps match. It is ok to buy a power supply with a higher amp rating, the monitor will only take what it needs. Also make sure the power plug that plugs into your monitor matches.
Nov 16, 2007 | Neovo SX-19A (Black) 19" LCD Monitor
Power problem?
Try ordering a new power adapter from Neovo. Call them up. It could't hurt. Apparently adapters are tricky items. I have no idea how much they cost, but if its reasonable it would be a fair tade for the nuisance you are dealing with now.
http://www.neovo-usa.com/
AG Neovo Technology Corporation
2362 Qume Drive, Suite A
San Jose, CA 95131 U.S.A.
Email: [email protected]
Tel: 408-321-8210
Fax: 408-321-8211
Nov 14, 2007 | Neovo E-19A 19" LCD Monitor
Neovo AG 17" LCD Monitor Logo
492 people viewed this question
Top Neovo Computers & Internet Experts
Dimitar Todorov
Leo Stuurman
Level 1 Expert
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
