Im getting very upset because i bought a renaul clio oasis 1.2 1995 on saturday and i have no idea how the winow wiper controls on the steering wheel work, its driving me crazy! I would like to no in each position the control is put in, what its does. Please please help.
If the radio works from the dash then unlikely to be a fuse. need to remove the steering shroud just behind the steering wheel and check for any loose connections is where I would start.
just get one from a junk yard to remove it just push turn and pull the only thing is that if the car has cruise control you got to cut the wire... and to install it your car push in and turn wiper will work signals but no cruise control unless you go trough steering coloum
if both controls are on steering wheel- short most likely in connection in the column where control arm goes into column- they are the two most used controls after the ignition and are not build as tough as the ignition
Im not positive cause i havent seen a 98 steering wheel but i know on the 92 you need to disable the horn and take the steering wheel off to get to the switch. I assume you have wires crossing. i would check it right away before you have a fire break out.
hey, i have recently bought a clio its 2001, 55,000 miles, when im accelerating its making a ticking noise, faster i go, quicker it ticks, do you have any idea?? xx
Study THe steering wheel look for Philips screw holes, that removes horn cover front, on back of steering wheel, once you take the front cover of the steering, do not loose any springs and screws, use the cars ashtray to collect parts, Looking at the front, You will see a NUT 22 mm or 19 mm grab a 1/2 pride bar with socket( with locked steering) anti clock wise loose nut and washer and remove them, after that tap steering wheel from back towards You with both hands at the same time, till wheel OFF, You will see the wiper control leveler and how to replace it
You have to use the Steering Wheel remote Control =========================================== Philips Renault Code Entry
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit Press the [ ¬] button then rotate the thumb wheel for the correct second digit Press the [ ¬] button then rotate the thumb wheel for the correct third digit Press the [¬ ] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen, press and hold the [ ¬] button for up to 10 seconds to store the code
