Question about Hardware & Accessories
Noma Multipurpose Timer, I pressed the grey buttons down and set it to the time I want it to start but the lights still won't turn on!
Posted by gurleen_kalk on
Anonymous
I answer questions for free.
I specialize in timers.
Noma is a Woods timer.
But Woods makes lots of timers.
I probably have the manual and can look up the information.
But I don't know without the model number.
If you know the model number, add a comment, and I will answer for free.
If you want to post a photo of your timer, I can look at it that way.
The following link shows how to include a photo of your product when you add a comment:
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Posted on Oct 31, 2010
How do I program a Noma timer model 052-8835-2
Try Googling (noma)(052-8835-2)(manual) without parens.
May 22, 2018 | Hardware & Accessories
Noma 052-8870-6
OUTDOOR DIGITAL BLOCK HEATER TIMER 052-8835-2 Instructions Plug timer into grounded outlet
To Set the Current Time: Press the HOUR button as many times as necessary to advance the display the correct time. Note, the time can only be set in 30 minute intervals. The LED display will display the hour (1-12) and on the half hour a light will illuminate in the upper right corner, next to the number 30. To change from AM to PM toggle 24 times, a dot will illuminate in the lower right corner of the display next to the letters PM.
To Program the Timer: Press the PROGRAM button once, the letter P will flash. Press the HOUR button to set the ON time. Press the HOUR button to set the ON time. Press the PROGRAM button again, the letter E will flash. Press the HOUR button to set the OFF time. Press the PROGRAM button to exit program setting mode. Press the HOUR button to review the ON/OFF setting.
To Connect/Operate the Timer: Plug device in to the timer and turn the device on.
To Revise the ON/OFF Setting: Unplug the timer and plug it back in. Repeat the programming steps above.
To Override the Timer: Press the PROGRAM button if you want the device to turn on before the preset time, but note the device will turn off at the preset time. For example, if the preset ON/OFF period is 3 pm - 4 pm, users can manually press PROGRAM to turn the device on at 2 PM, the timer will keep running until the preset off time at 4 pm.
Suitable for use with outdoor appliances. Raintight when mounted vertically with the receptacle facing downward. Use a three-conductor GFCI protected outlet. Do not immerse in water. DO NOT EXCEED RATED CAPACITY. Not for permanent installation. Do not install or use this product for more than a 90-day period per year.
Dec 02, 2013 | Hardware & Accessories
Hi, I have a Dell printer, and it says "MPF Load Error" every time I try to print something. How do I fix this?
Verify the Paper Type Matches the Type Set in the Printer´s Operator Panel
To verify the paper type matches the type set in the printer's operator panel, perform the following steps:
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Type appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper type, as shown in Table 1, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
Print from the Multipurpose Feeder (MPF)
To print from the Multipurpose Feeder (MPF), perform the following steps:
  1. Click the Start button, point to Programs, point to Accessories, and click Notepad.
  2. Type the word test.
  3. Click File and then click Print.
  4. In the Print window, verify that the Dell 3000cn / Dell 3010cn / Dell 3100cn printer is selected in the Select Printer dialog box.
  5. Click the Preferences button.
  6. In the Printing Preferences window, click the Paper Tray tab.
  7. Click the Paper Source drop-down and select MPF.
  8. Click OK.
  9. Click Print.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 19, 2011 | Dell 3010cn Laser Printer
How to set the Nordik TM-065? It was bought for
The Nordik TM-065 timer looks similar to Woods/Noma N1506
http://www.advancedtimer.com/TM-065.html
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1506
Plug timer into outdoor receptacle.
Press Time button until correct time displays.
Dot on display is for pm hours
Nordik appears to be on the 24 hour clock instead of am-pm
Set operation of timer by pressing Mode button.
P flashes for program mode.
Press time button until starting time displays.
Press Mode again and E flashes.
Press time button until finish time displays
Press Mode button to exit programming.
Dec 17, 2010 | Woods Outdoor Lighting Timer
How to reprogram my Woods N1506 Timer
Manual and image for Woods/Noma N1506 outdoor timer
SETTING NOMA N1506 TIMER
Plug in timer - The letter C will Flash
TO SET CURRENT TIME:
Press Time Button - It will advance to 1 a.m.
Continue pressing until right time to the nearest hour.
Timer is only set to nearest hour.
(NOTE: A dot at the bottom right corner of the display indicates P.M. hours).
TO SET ON AND OFF TIMES FOR TIMER OPERATIONS:
Press Mode button - Letter P will flash inviting you to set the program
Press Time button repeatedly until required staring time appears in the window. (starting time is now displayed).
Press Mode button again - the letter E now flashes.
Press time button repeatedly until required ending time appears in the window. (Note: a dot at the bottom right corner of the display indicates P.M.hours).
Press Mode button and the display returns to the current time.
Programming is now complete. You may now plug in whatever needs to be turned on. The device will turn on and off automatically every day at the times you have just selected.
TO REVIEW THE PROGRAM
Press time button - Displays successively, for 1-2 seconds each: P, starting hour and E, ending hour. Then returns to show the current time..
TO CHANGE YOUR PROGRAM
Unplug the timer, which will discontinue the current program. After 10 seconds, plug it in again and proceed to set current time. Then continue with the programming steps as above.
FOR MANUAL OVERRIDE
Pressing the Mode button at any time will turn on the devices plugged into the timer. The display will indicate the letter O. The devices will remain on until the ending time of the daily program. To return the timer to the automatic mode prior to that hour, press the Mode button again. The display will return to show the current time.
AFTER A POWER INTERRUPTION/FAILURE
The timer will return to displaying a flashing C and the devices plugged into it will be off.
Dec 13, 2010 | Woods Outdoor Lighting Timer
How to program my Woods N1506
FOR MANUAL OVERRIDE
Dec 13, 2010 | Woods Hardware & Accessories
How do I program a Noma N1506 timer?
All Woods timers and manuals
N1506 manual:
http://waterheatertimer.org/pdf/Woods-49122-N1506-manual.pdf
N1506 is heavy duty outdoor timer with display screen.
Plug timer in and display flashes C.
Set current time: press Time button once and display shows 1 am
Keep pressing time button until current time with am pm displays.
Dot in lower right corner corresponds to pm hours.
To set timer program:
Press Mode button, display flashes P
Press Time button until desired ON time displays.
Press Mode button again and display flashes E
Press Time button until desired OFF time displays
When programming is finished, press Mode button and display shows current time.
To reset timer, unplug timer for 10 seconds and re-program timer.
Timer must be reset after power outage. Display will warn by flashing C.
Plug lights into timer.
If lights have a switch, switch must be on.
For manual override, press Mode button, and display shows O and lights will be ON until next program change.
To use timer function, press Mode button until current hour displays.
Dec 12, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
How do I set my Woods N1506 timer?
According to another fixya answer posted December 4 2009:
FOR MANUAL OVERRIDE
Nov 23, 2010 | Woods Outdoor Lighting Timer
I need instructions for using my N1506 timer.
Plug in timer – The letter C will Flash
Press Time Button – It will advance to 1 a.m.
Press Mode button – Letter P will flash inviting you to set the program
Press Mode button again – the letter E now flashes.
Press time button – Displays successively, for 1-2 seconds each: P, starting hour and E, ending hour. Then returns to show the current time..
FOR MANUAL OVERRIDE
Dec 04, 2009 | Woods Hardware & Accessories
Lost instuctions to program Model N1560 Noma outdoor timer
Use the top button to adjust the current time & then push the bottom button once to save. Next is the time you want the lights to turn on & push bottom button once to save. The last setting is the time you want the lights to turn off. Don't forget to use the . (period) indicator for the pm setting. (I had the same problem and had to search the net to find someone else who had posted the instructions.)
Dec 01, 2008 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
Hardware & Accessories Logo
132 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
