SOURCE: Blowing the amp fuses
do you have speakers connected as well? do you have a volt meter
make sure you are getting + from both are you sure the remote is not a 5 volt line?
If the power supply transistors blew out, it's possible that the output transistors have failed (shorted).
If you're going to try to repair it, there are likely 2 blown driver transistors near the driver IC (TL494). You must check them. If they're blown, the new 3205s will blow out again.
SOURCE: hey guyz i have a kicker zx1500.1 amp and i had a
i reccomend replace it , it will never be the same
SOURCE: how come it blows 30 amp atc fuse instantly
check connections are hooked up properly if it blowin the fuse with it off sounds like something is really wrong on inside get it checked out
