Samsung TX-R3080WH 30" TV Logo
Posted on Oct 31, 2010
Hello all. I have txs3082whx/xaa, the problem is that screen is too zoom in, edges doesn't display correctly, this issue happen in 4:3 and 16:9 mode, I tried to changing options in picture image, can someone help me please? Thanks
2 Related Answers
Anonymous
  • Posted on Jul 22, 2009
SOURCE: my tv txs3082 blink constantli
Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
Anonymous
  • 443 Answers
  • Posted on Feb 09, 2010
SOURCE: I have a HDTV Samsung TV, Model #TXS3082WHX/XAA
Look for a monitor cable with 15 pin RGB plugs on each end, that will transmit the video portion of the signal so you will need an audio cable with 3.5mm plug on each end also, there are RGB cables that have the audio cable together as one big cable.
Good Luck !
Jvc lt-47em59 picture too large in all aspect modes
Larger as in -- the screen looks fatter. 4:3 stretched to 16:9 or as in Larger as in, screen is longer but thinner? 16:9 / 10 fitting onto ratio 4:3?
Asuming... its the second one -- that ur screen is box 4:3 and the picture is huge 16:9 which is why u need to "zoom out" to get the full picture -- are u sure some idiot didnt mess with the settings and make the tv "zoom in" if it isnt a aspect ratio issue?
... if it is a aspect ratio issue, and ur using 4:3 (small old box televisions) there should be a ratio setting either on ur television OR on ur set top box, that would by defualt with digital tv have wide screen 16:9 -- id suggest finding the settings either on the tv or the set top box or...
just get a bigger tv that supports 16:9 cheap for 50 bucks.
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
The picture is outside the edges of the TV
It's probably an issue of the "Aspect" or the "Screen Mode" you're in. I'm no TV repair expert, but if you look in your Main Menu for "Screen Mode" or even your remote might have a button labeled "Asp" or "Aspect" or "Mode"....or even "Wide" (which when pressed repeatedly will cycle through the most common 4 screen modes = Wide, Screen Fit, Zoom, 4:3.) The last one refers to the ratio aspect, but depending on your TV, they could be named differently.
Given your description, it seems you're in "Zoom" mode, since it's cutting off the edges of the picture. Put it on a station like CNN, which has a streaming ticker at the bottom and cycle through the options you have until you find the one you prefer. (Note: you should also be able to set this in your Main Menu somewhere as your preferred view, but some shows and movies might come through as full screen or 'Letterbox' regardless of your preference.
One final observation I've found on several units is that the remote button that's in the bottom right-hand corner (which may not be labeled as such) is the default location for your aspect selections. Push it and see what happens.
Sony bravia picture to large for screen
Sir press the screen mode button in your remote below input select button, press the screen mode button repeatedly to select smart, 4:3, wide, zoom, or 14:9.
  • Smart- Display conventional 4:3 broadcast with an imitation wide screen effect. The 4:3 picture is stretched to fill the screen.
  • 4:3- Display conventional 4:3 broadcast non-wide screen TV in the correct proportions.
  • Wide- Display wide screen 16:9 broadcast in the correct proportions.
  • Zoom- Display cinemascopic letter box format broadcasts in the correct proportions.
  • 14:9- Display 14:9 broadcasts in the correct proportions. As a result, black border areas are visible on the screen.
I just connected my laptop to my samsung model txs3082whx xaa and with an hdmi cable and my computer says that it does not detect a second montior. my tv is not hooked up to any cable its just plugged into...
The computer's operating system may need you to manually tell it to configure the HDMI. Sometimes I get this issue; I just click "detect displays" to refresh the data input, and then the laptop realizes there's an HDMI cable inserted and thus recognizes the monitor.
I have connected my laptop to my sony 40ex403 bravia. The screen is centred on the tv screen. How do get it to full screen size?
Hello.
On your TV remote control there is button "Picture mode" or similar name. You can change image to "zoom" or "wide" by using it. Sometimes if in "zoom" mode it still not fill whole screen - you have to change display settings in you notebook for external display.
Regards.
Russ.
My tv txs3082 blink constantli
9helpful
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
