If you just need to raise the height of the stem, all you need to do is loosen the hex nut at the top of the handlebar stem with a box wrench or adjustable wrench. This is the head of the stem bolt. Once loosened enough the stem should slide up and completely out (if necessary) of the stem casing. There is a tightening mechanism consisting of two soft metal pieces that tighten against each other when the stem bolt is tightened. When this is loose you can raise the stem to various heights. If you find you cannot raise it to your desired height you may need to replace the stem and bolt. However, if the bike has been sized properly to fit your leg length, you should have no problem there. Once the height of the stem is satisfactory just tighten the bolt while keeping the stem straight and you'll be ready to go!
