NRS Hoveround MPV 4 - Hovaround Used Electric Wheelchair Logo
Posted on Oct 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When mvp4 is turned on the battery lights come on and then go out and the speed indicator lights come on flash several times and then nothing.
Anonymous
Level 3:
  • Master 692 Answers
  • Posted on Oct 31, 2010
Anonymous
Master
Level 3:
Answers
692
Questions
0
Helped
288774
Points
1801
Count the number of flashes this will give you an error code and you can determine the error by the number of flashes your users manual should list the error codes and their meaning. If not call Hoveround Tech support for help Hope this helps you
WHEN POWER ON CHAIR SPEED LIGHT BLINK .BOTH BATTERY WAS REPLACE AND JOYSTICK.SAME PROBLEM
The battery meter lights will flash a flash code when something is wrong. If the lights are flashing the same number of lights each time. get that number it is a flash code. if the lights are cascading up and down that indicates that the Joystick is locked. unlock by turning on the joystick and pushing the horn button twice within 10 sec. of turning on. Or push on button and hold the joystick gimbal forward until it beeps then back until it beeps. This should have it unlocked, if not Pride Jazzy Tech 800-800-8586
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Minolta auto 280px
Did you put them in the right way? did you check all contacts in the speed light / electro flash? is needed, please clean the contacts. If you did not use this speed light for a long time, some contacts (also from the switches) could be corroded. when you sure you have the right batteries, correct inserted, and it won't start. try pushing the on / off several times. ( no pressure will be needed)
Don't use manganese (Zinc-Carbon) batteries. Best choice would be NiMH.
Nov 26, 2013 • Cameras
I am reposting this question with more detail in hopes that someone can help me! I have Lenovo Y550 that has been sitting for several months without being used. It was working fine the last time it was...
You may need to remove all the power from the device including the CMOS Battery. As well try using an external display to see if there is any display.
I have an 8710 workstation and it has worked fine for many months. Recently I've been having problems powering it on. I use a docking station and when I try to power it on in the morning -- the power LED...
Flashing orange light generally indicates battery low charge could be your battery at fault
the next time you try and power on and it doesnt work, take the battery out (unplug AC) and try to run just on AC power
hope helps, let me know if can help further
4helpful
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
My Quantaray QTB 7500A will not turn on. Placed
Make sure your batteries are inserted properly (+/-) Slide the battery cap on and off several times to make sure you have good contact.
1helpful
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
This started last night, my battery indicator
The red or amber flashing lights indicate a bad battery. The Dell battery warranty is only for one year and the D600 has been out for a number of years. You should replace the battery. You can use the laptop as it is as long as it is connected to AC power.
There are several places to buy replacement batteries. One is www.bixcomputers.com. If you do a search on the web you should be able to find other sources.
Good luck and I hope this helps, even if it isn't good news.
My sony ericsson k800i will not switch on. if i hold the power button down, a small red light comes on, but nothing else. any help would be much appreciated. thank you
That red button ur talking that flashes several times indicates that ur battery is dead, and it has to be charged...
Anyway if that doesn't work then u'll have to flash up ur mobile at a trusted sony ericsson support center...
Apr 03, 2008 • Cell Phones
Top NRS Health & Beauty Experts
ADMIN Andrew
ADMIN Andrew
Harsal Patel
Harsal Patel
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
