The first thing to determine is if the unit is brushless type. If it has brushes, the rectifier module MIGHT be a problem, but more likely is the field has lost its remaining magnetism and needs to be "flashed".
HOWEVER if it is brushless, the field there would require special methods to restart. Search google for brushless generator problem and look for method using series light bulbs and utility power.
NOTE. sometimes a short inadvertently placed on the brushless units will pop the roatating diodes which then must be replaced.
Take a look on the generator, thats the one charging the battery, the coals in the generator might be needed to be replaced, there are two of them, Also check the two cables from the generator so they arent dameged or broken. You can take the bike to a repaire shop and ask them to help you measure if the generator gives enough power to charge the battery or on, the can measure the power on the generator and they can measure the power coming to the battery.
Im sure the the problem is the generator or the cables from the generator
Visit this site http://www.perr.com/phpBB3/ and they can tell you how to flash your generator. Might I suggest you run the generator often and put it under load even if you're not depending on its power output at the time like you would in a power outage. Like use it to power a shopvac or similar device.
You have to Call 1-800-4my-xbox.
Then tell them what happened, you will have to mail it out with the Console, and the plugs.
Dont mail out the hardrive or disc.
They will send u a brand new console.
Hope this Helped.
