Sony Xplod 1100 Watt Max 10" Subwoofer, XS-L100P5W Car Speaker Logo
Question about Sony Xplod 1100 Watt Max 10" Subwoofer, XS-L100P5W Car Speaker
What size amp should i get for 1 1100 watt subwoofer?
Posted by pmellmer on
2 Related Answers
Anonymous
  • 74 Answers
SOURCE: need an amp to go with speakers
you could get a 1100 watt amp, but, it is ALWAYS good to get a smaller amp than the max rating so you have a "safe" zone and turn it up all the way so you don't have to worry about always running it at its peak( which sounds better but more chance of blowing it)
Posted on Feb 18, 2009
Anonymous
  • 6 Answers
SOURCE: Subwoofer and amplifier wattage problem
No it will sound good if you can put an amplifier with 500 watts rms it will sound better
Posted on Jan 30, 2010
What kind of amp can adequately power P112 S8 subs
you shouldnt run it at 8 ohm it shows what ohms it can handle . to run it at 1 ohm you would need 2 subs to do this. and no i wouldnt run an 8 ohm sub on the amp.
I have power akoustik 12"
If you sub is dual 4 ohm voice coil, you can get a 4000 watt amp (which will give you 1700 watts RMS at 2ohms). The model number is OW-BAMF40001D. Hope this helps.
What size amp needed with a sony explod player?
this bandpass enclosure is rated peak power at 1200 watts . what this means is that each subwoofer in the is peaked at 600watts to make 1200 watts . what your looking for is to power up the subs with rms continuous wattage . you need an amp that will put out 400 to 500 rms a channel to run this sub enclosure at 800 to 1000 watts rms to keep the speaker from blowing
audiopipe apf1801
71671968.jpg this amp will give you 1 channel @ 4 ohm x1 350 watts 1 channel @ 2 ohm x1 900 wats 1 channel @ 1 ohm x1 1800 watts you would have extra power for better subs with more power later but you get 900 watts which when connected right would mean 450 watts per sub be perfect for you . i sell this for $320.99 in my store can shipp any where in usa to contact me [email protected]
1helpful
What size amp or watts needed to power a JL 12" w6?
these subs are rated at 400 watts rms ... hope this helps
What size amp do i use with 2 1100 watt 10" sony subwoofers
I have the same set of speakers and im running a kenwood 2 channel amplifier thats bridged and it works well.
What size speaker wire do i use with the mofo 15 from the sub to the box then the box to the amp
The size of the wire has more to do with the amp's output than it does with the speakers. The wire should be the same size throughout, from speaker to box, box to amp. A minimum of 16 guage multi-strand wire. Most amps that put out up to 500 watts max or have an RMS rating in the 300 watt range should do fine with this. If you want to be on the safe side, there is no limit to how big your speaker wire can be, only how small or a minimum. If you're using a very high output amp, like over 500 watts RMS, you can use 12 ga. wire. If you want to be on target for your size, I need to know what amp you have and how many speakers you have.
2answers
Hi i have two 10'' jenson xs sub and they are about 6 years old and i was wondering wut amp size i should buy to run them.
I believe these are 4ohms, if so buy a 2ohm stable monoblock amp, that puts out 250-300 watts RMS, and connect your subs to it in parallel, don't pay attention to peak watts, look at RMS watts, or continuous watts. If they're 2 ohms, buy a 2 ohm stable 2 channel amp that puts out 125-150 watts RMS per channel, and 250-300 watts total or bridged RMS output. And connect them normally, on sub per channel... hope this helps, as far as brand recommendations, MTX, pioneer, Alpine, Kenwood... Good luck
What to do
well i don't know your budget, but if that's not really and issue, right now at best buy, alpine type E, 10" subs, peak is 750w and rms is 250w, each is 129.99. Alpine type R, 10" subs, peak is 1500w and rms is 500w, each is 199.99. These are the best subs i found at best buy. You could sell your current subwoofers and purchase those, and you'd save space and still get the lows you want. Goodluck
Need an amp to go with speakers
2answers
What amp size do I need
If the subs are going to be wired at 2 ohms you will need a class d amp that is 1200 watts at two ohms rms i would say you should probably be running zero gauge wire and at least a two fared cap
Top Sony Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
