I'm on my second grinder of this model.......... in the past 2 months. The first stopped working so I just took it back and replaced it. The second time it quit working I removed the cup with the grinded coffee and noticed smoke wafting up from the unit. Both times it quick working I was grinding 12 cups of beans (12 cups of brewed coffee, not 12 cups of actual beans). The unit shouldn't have a setting to grind that much coffee if it burns the motor out, which is what happened.
I had the same thing happen to mine, smoked after grinding then nothing. I opened it up and checked for any burnt components. There is a component attatched to the motor where wiring connects to the windings. Its either a diode or capacitor that is rated for 10 amps. If you bypass this component, the motor will run again.
SOURCE: coffee grinder ge model no.111338
check the rley is in good condition.(by unplugging all the wires and check the continuity between the terminals).
second by checking the grinder coil resistance that its not showing open .
third might be something stuccked in the grinder.(rarely)
thanks
please rate my work
