Solution : Replace the Imaging Unit
The life of the Imaging Unit is approximately 20,000 pages for black and white, or 12,500 pages for color. When the life span of the Imaging Unit has expired, the Smart Panel program window will be displayed on the computer, indicating the unit needs to be replaced; otherwise, your printer will stop printing.
WARNING: Some parts inside the printer may be hot when the printer is powered ON, or after printing. Be careful not to burn yourself when working inside the printer.
To replace the Imaging Unit:
Click on the [Recycling] link under the Product Resources menu on this window.
CAUTION: Do not use sharp objects, such as a knife or scissors, to open the Imaging Unit package as this could damage the surface of the unit. Be careful not to scratch the surface of the unit.
Do not expose the Imaging Unit to light for more than a few minutes. Cover it with a piece of paper to protect it, if necessary.
NOTE: Each LED on the Control Panel blinks red in a repeated order. Wait for about three minutes for the printer to reach a 'Ready' status.
NOTE: If there is a cracking sound, re-install the Imaging Unit.
If error like "Replace Transfer Belt" appears when you try to print something then it means that the transfer belt has come to its end and will need replacement. The best solution is to replace the belt. Even if the errors can be clear temporarily by reset procedure, possible that this error will appear again.
Below is the procedure to Reset the printer
1. Enter Service Mode by pressing [MENU] [#] [1] [9] [3] [4]
2. If Tech Mode Menu did not appear ...press the MENU button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press Enter
6. Enter Password 1934
7. Arrow to Transfer Belt and press Enter.
The display will show Clearing Counts and then return you to the Tech
Menu. Press exit several times to exit the Tech Menu. Turn off the printer then turn on again.
Thank you for using Fixya.
Alp
where is the menu button?How do I get in service mode?
thanks for the solution but how do I get in tech mode?Were is this menu button?
Will you please give me the right answer the printer now doesn't work at all. please what is the menu button for my model?
can you please tell me the menu button for my model?and the reset for my model please?
thanks for your support I will try to do what you advised me.
