Question about Tag Heuer 2000 Classic WK1311 wristwatch
I cannot pull out the time setting screw on the rhs of a ladies wn311 Tah Heuer.
Posted by maree_zammit on
Michael
    Sergeant:
  • 302 Answers
The time setting screw is more accurately called the crown which is, in your case, a 'screw down crown'. This is done for water resistance. You must first unscrew the crown before you can pull it out. When you are finished setting the watch you must screw it back in. It may require that you press in on the crown and turn it at the same time to get the threads to catch. No need to overtighten it.
Posted on Oct 08, 2012
1 Related Answer
Baabaabing
SOURCE: Tag Heuer Ladies Professoinal 2000
Hi Dude, it's one of those things your going to cuss once you know. Just unscrew the Bezel.Thats it. Steve
Posted on Mar 15, 2008
How do I set the time on a professional tag heuer ladies watch
You have to unscrew the crown once it is unscrewed can you pull it out once for the day and twice for your time. Be sure to screw the crown back in when you're finished or else you'll get moisture inside.
Mar 05, 2015 | Tag Heuer Watches
Tag Heuer watch losing time
Make sure the voltage on the new battery is correct. Just because a battery is new does not mean it is good. That is likely the problem.
Apr 21, 2012 | Tag Heuer 2000 Classic WK1320.BB0316 Wrist...
I want to know how to change the clock. Tag Heuer 2000 Classic Silver Dial Steel WK1312-0
Hi! your watch probably has a screw down crown which is a feature found in well made watches. Turn the setting mechanism on the watch until it unscrews then pops out a little , pull it out two clicks to set your time, and one click to set your date. The one click setting can tricky it is what we call a halfway setting but you will feel it pulling the stem in and out. Then make sure to screw the crown back in this is a water resistant feature. Thank you! hope this helps:)
Sep 06, 2011 | Tag Heuer Watches
How can i make the date of my tag heuer formula 1 change automaticaly?
To s e t t h e t i m e a n d d a t e
Your TAG Heuer chronograph is fitted
with a screw-in crown and safety seals
which guarantee it to be waterproof
to 200 m (660 ft).
Position 0: Crown is screwed in
(normal position).
Important: The crown must be
screwed in correctly to guarantee
the water-resistance of the watch.
Position 1: Crown unscrewed.
To change the hour (change of time
zone) or date quickly, unscrew the
crown, pull it out to position 2 (quick
corrector) and turn it in either
direction. This mode allows you to
change the hour and the date without
any loss of minutes.
The date changes each time the
hour-hand passes midnight.
To set the time, unscrew the crown,
pull it out to position 3 (setting the
time) and turn it in either direction.
After setting the date or the
time, push the crown back and
screw in to position 0.
Oct 10, 2009 | Tag Heuer Formula One
Tag Heuer watch
The knob is a screw-cap seal. When closed (screwed in) it closes the chamber to prevent water from entering the watch.
You will need to unscrew it. It should snap out. In this position, you can wind the watch. Pull the knob out one click, and you can adjust the date. Pull the knob another one more click, and you can adjust the time.
Push the knob back in. In order to seal the watch back up, you will need to push the knob in while turning the knob. You will know you did it correctly when the knob will not turn any further.
Good luck.
Dec 25, 2008 | Tag Heuer AquaracerWAF1110.BA0800 watch
Help setting the time
Tags have a screw down crown (winder knob) turn the knob counter clock-wise until you feel the crown unscrew (not off) then pull the crown carfully. It will pop once this is for date adjust. Then pull once more and you can now adjust the hands, set accordingly then push crown back in. After you push it back in gently compress the crown and tighten clockwise until it stops. CAUTION!!!!!!! Tags are not waterproof if the crown is not screwed back down. I hope this helps I am actually a car guy (just happen to own a couple)
Nov 06, 2008 | Tag Heuer WAF2110.BA0806 Aquaracer...
Mar 15, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
Ladies aquaracer 300 meters
the crown is a screw down type to keep the watch water tight. Unscrew the crown (what you refer to as the dial) and you will then be able to set the date, time, etc. and be able to wind the watch manually. P.S. You unscrew the crown by rotating it counter-clockwise.
Jan 27, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
Tag Heuer Aquaracer calendar problems
You have to unscrew the knob first then you will be able to pull it out to change the minutes, hours, date. You may have to use a pair of small pliers to initially turn the knob.
Aug 24, 2007 | Tag Heuer cj1110.ba0576 Wristwatch
Tag Heuer 2000 Classic WK1311 wristwatch Logo
190 people viewed this question
Top Tag Heuer Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
