That means that the receivers' overload protection circuitry has been engaged. Depending on the number that is also displayed after the alarm message, there are several causes for this. Overheating, running inefficient speakers such as below approximately 85dB/1W/M rating or too loud a volume with demanding source material and last but not least a loose connection of any kind on the rear panel or on any of the devices connected to it. Especially the speaker cable.
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be with your output drivers. Please check for short on the outputs fitted for both the channels. Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise which can be a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board. Maybe the protect circuit by itself is shutting off due to a faulty bias or there is a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the amplifier comes out of the protect mode then check for short on the speakers.
