Question about Western Digital External USB 2.0 80 GB Hard Drive
Blinking light flashes continually. The pc can not access the eternal hard drive. I have re-started the pc several times and the pc will not recognize the external hard drive. The WD External Hard Drive icon has disappeared.
    New Friend:
  • 73 Answers
Try to connect the usb port properly maybe there is a loose contact. and try to remove all the gadgets connected in the computer... only connect the external HDD
Posted on Oct 30, 2010
What does a blinking hard drive light mean?
A blinking hard drive light indicates hard drive activity. It means that the hard drive is performing certain operations. There are many programs running in the background that need to access the hard drive to read and write data. Whenever this happens, the hard drive indicator light blinks.
Although, if it's blinking continuously and causing the system to slow down, it could also indicate that the system is low on resources such as RAM or hard disk space or it is infected with Malware. In that case, you'll need to check your system configuration. You should run a full antivirus/antispyware scan to make sure the system is clean.
GuruAid.com
May 25, 2014 | Dell Dimension Computers & Internet
Blinking courser when start my pc and continue blinking then esc courser will stop blinking but after some time again blinking courser
Pls check if the Hard drive is detected in BIOS.
If Yes, then run a test on the Hard drive.
If the test fails, the drive has to be replaced.
If the test passes, then load the BIOS defaults and check if the comp boots to windows.
If it still doesnt boot, then you will need to reinstall the OS from the OS disks.
Oct 15, 2013 | Computers & Internet
I have a Dell 2400 Desktop that all of a sudden won't access the login screen. It powers on then the hard drive makes noise with the green lights blinking but it then says press F1 to continue but
First thing, check to see if the is a floppy disk in the floppy drive, if so removes this disk. If there was no disk in the floppy drive then it may be a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.
If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.
To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.
Nov 05, 2012 | Computers & Internet
Suddenly, my 500GB Seagate external hard drive couldn't mount on my iMac. It was working fine till yesterday. I connected them to the Mac USD port, and the light in the seagate is blinking... Any
I can only comment generically:
I would try to uninstall the drive on the OS. Then re-start the computer. After the re-start, connect the drive and see if the drive re-installs itself.
If the error persists, then the drive is indicating failure. To absolutely verify if it has failed, take the drive to a store where there are MAC computers and try the drive on one of their computers to see if it works.
A continuous flashing LED on most devices where the LED does not normally continuously flash is an indication of a failure of the device. Some devices will flash an error code when designed to do so, and if possible.
Jerry G.
Aug 14, 2012 | Apple iMac 17" Desktop
WD Myworldbook white strip flashing
The 'blinking' light simply means the unit needs tending to. Once acknowledged, via config, the flashing light will stop. Sometimes your anti-virus program will block you from getting into config. So you might have to turn your AV off.
Sometimes the blinking starts because the drive is over 95% full and sometimes it means one of the drives inside is failing or has died.
Run the WD Discover Tool, go into to "configure", & acknowledge that over 95% of the drive is used if that's the problem. Once you do that, the blinking light will go away & work like it did prior to the blinking light.. If a drive is failing then you might need to RMA it.
Jun 10, 2012 | Western Digital My Book World Edition II...
Light flashes continuously
The external drive has gone belly up. You can try it on another usb port and also on another computer just to satisfy yourself, but the drive has croaked.
Jun 05, 2012 | Maxtor OneTouch II 300 GB Hard Drive
When placed in port, the light flashes several times and goes out
> light flashes several times, and goes out
That is "normal" activity -- the "table-of-contents" is read from the flash-drive (and that I/O activity turns the lamp on) and when there is no I/O activity, the lamp goes off.
If the lamp stays off when you try to access the files/folders, then the flash-drive has "died". Spend $9 to buy a replacement.
Contact SanDisk -- if the warranty still is valid, you can get a replacement, for minimal cost.
Nov 01, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Light on front just blinks
this could be for several reasons. Normally a light blinking on a hard drive is to say that the disk is being accessed. but if it happnes for a long period of time, then you might have a issue with the disk itself.
i suggest that you try the device on another PC, a friends or relatives. if you have the same problem , i am afraid that you might have a disk error
May 06, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
My Dell Studio 540 blinking hard drive light
the hard drive light blinks whenever the Hard drive is accessed, and sine this is where everything is stored, that happens a lot. the only way to completely disable it is to unplug it from the motherboard.
Jan 15, 2010 | Computers & Internet
What are the blinking light error codes for
the interphase between the raw drive and the usb cable is faulty or blown up.
use the raw drive from the casing to power it directly to pc it would start working
Sep 19, 2009 | LaCie F.A. Porsche (301177) Hard Drive
Western Digital External USB 2.0 80 GB Hard Drive Logo
507 people viewed this question
Top Western Digital Computers & Internet Experts
Ekse
ChinthakaJ
ChinthakaJ
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
