Question about eMachines W3507 PC Desktop
I want to add more memory into my emachine w 3507...Intel Celeron D Processor 352/Processor 352. It has one ram in there now with the phone/line jacks. How don't know how many rams are on there? How much do i add?
Posted by selenabanks0 on
Anonymous
    New Friend:
    Problem Solver:
  • 4 Answers
The RAM will max out at 2GB.
It takes 240 pin DDR2 PC2-530 according to my research
Posted on Oct 30, 2010
I have emachine with 1 gig ram want to add another gig
Try using memory store dot com. They have a small executable that will discover and tell you exactly what you need. Or you could use their search. Both work fine. This is just a suggestion, but other sites may have the same features. GL
Jan 28, 2013 | eMachines Desktop / Intel Celeron...
Installing new cpu on a emachine
According to the specs I have Serena, the eMachines eTower 633i Desktop PC, uses a TriGem Cognac motherboard.
[TriGem is the manufacturer, Cognac is the model.
Note it is Not the TriGem Cognac+ ]
http://www.motherboards.org/mobot/motherboards_d/Trigem/Cognac/
Specifications. (You can click on the photo to enlarge)
PDF motherboard manual,
http://www.elhvb.com/mboards/TriGem/manuals/index.html
Click on - Cognac - in the left side of the list.
Going back to the Motherboards.org page;
(Nothing like upside down photo information, and the motherboard is turned 90 degrees to the Right, to how it actually sits in your computer case )
The processor socket is a Socket 370,
http://en.wikipedia.org/wiki/Socket_370
Used for Intel Pentium III processors, and intel 'Celey' processors.
(Excuse me......Celeron.
An Intel Pentium III processor has TWICE the L2 cache, that a comparable Intel Celeron has.
The cache for a Processor is a small memory area for the Processor.
It is the First memory the Processor accesses.
The Ram Memory is second, and the Harddrive is third.
More cache for a Processor makes it more faster )
The motherboard chipset is an Intel 810.
The Northbridge chip of the motherboard chipset, is an Intel 82810.
The Southbridge chip is an Intel 82801AA, or an Intel 82801AB.
(Intel ICH, or Intel ICH0 )
Looking at the chart, and reading across, you can see what the Intel 810 motherboard chipset supports;
1) Processors: Intel Celeron, or Intel Pentium II, or Intel Pentium III.
2) Processor Front Side Bus: (FSB) 66MegaHertz, or 100MHz.
3) SDR Sdram ram memory at 100Megahertz.
[Single Data Rate Sdram is often just referred to as Sdram.
Erroneous.
Double Data Rate Sdram is also Sdram (DDR Sdram)
Synchronous Dynamic Random Access Memory
So is DDR2 Sdram, and DDR3 Sdram ]
Also referred to as PC100.
So when looking for a CPU you look for;
1) Fits in a Socket 370 processor socket.
Yep. The best is going to be an Intel Pentium III.
2) Has a FSB of 100MHz.
Hmmm,............
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_III_microprocessors#.22Coppermine.22_.28180_nm.29
Scroll down.
Pentium III 1100.
Maximum frequency rate ('Speed') is 1.1GHz (1100MHz)
Front Side Bus = 100MHz
Uses a Socket 370 processor socket.
Part Number = RB80526PY005256
sSpec Number = SL5QW
http://www.cpu-world.com/CPUs/Pentium-III/TYPE-Pentium%20III%20%28Coppermine%29.html
http://www.cpu-world.com/CPUs/Pentium-III/Intel-Pentium%20III%201100%20-%20RB80526PY005256%20%28BX80526F1100256%29.html
In the top header -
Specifications / Pictures (1) / CPU ID (1) / Comments (1),
click on Pictures (1)
You can click on the photo to enlarge.
256MegaByte of L2 cache. (256MB)
A comparable Celeron would have 128MB of L2 cache.
http://www.recycledgoods.com/products/Intel-SL5QW-PIII-Processor-1100-256-100-1.75V.html
http://www.impactcomputers.com/sl5qw.html
[ Don't forget to follow Anti-Static Precautions.
Clean the bottom of the Heatsink THOROUGHLY, and the top of the Processor if it needs it. (I always do anyway)
PROPERLY apply fresh, new Thermal Paste.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 26, 2012 | E-Machines etower 633is PC Desktop
My gigabyte motherboard will support single chip 2gb ram and i have to upgrade my ram into ddr2 533mhz to ddr2 667mhz or 800mhz it is possible for my motherboard
Gigabyte GA-945GZM-S2 - motherboard - micro ATX - LGA775 Socket - i945GZ specifications
  • it looke like the supported RAM
  • Supported RAM Technology DDR2 SDRAM
  • Supported RAM Speed 533 MHz , 400 MHz
  • hope this helps
  • General
  • Product Type Motherboard - Micro ATX
  • Cache Memory None
  • Chipset Type Intel 945GZ Express / Intel ICH7
  • Max Bus Speed 800.0 MHz
  • Processor Socket LGA775 Socket
  • Max Processors Qty 1.0
  • Compatible Processors Core 2 Extreme , Celeron D , Core 2 Duo , Pentium D , Pentium 4
  • Memory
  • Max Supported Memory 2.0 GB
  • RAM Features Dual channel memory architecture
  • Graphics
  • Graphics Controller Intel GMA 950
  • Memory Allocation Technology Dynamic Video Memory Technology 3.0
  • Audio
  • Type High Definition Audio (8-channel)
  • Audio Codec Realtek ALC888
  • Compliant Standards High Definition Audio
  • LAN
  • Network Controller Marvell Yukon 88E8001
  • Network Interfaces Gigabit Ethernet
  • Modem None
  • Expansion / Connectivity
  • Expansion Slot(s) 1.0 x Processor ( 1.8 V ) - LGA775 Socket ( x4 mode ) , 4.0 x PCI Express x16 - DIMM 240-pin , 3.0 x Memory , 1.0 x PCI
  • Storage Interfaces Intel ICH7 : ATA-100 - connector(s): 4 x 7pin Serial ATA - 4.0 device(s) , Intel ICH7 : Serial ATA-300 - connector(s): 1 x 40pin IDC - 2.0 device(s)
  • Interfaces 1.0 x Audio - Floppy interface - Mini-phone stereo 3.5 mm , 1.0 x Storage - Line-out - 6 pin mini-DIN (PS/2 style) , 1.0 x Audio - RS-232 - 25 pin D-Sub (DB-25) , 4.0 x Serial - VGA - Mini-phone 3.5 mm , 1.0 x Microphone - Line-in - 15 pin HD D-Sub (HD-15) , 1.0 x Keyboard - Generic - 6 pin mini-DIN (PS/2 style) , 1.0 x Display / video - IEEE 1284 (EPP/ECP) - 4 pin USB Type A , 1.0 x Audio - Line-out (center/subwoofer) - Mini-phone 3.5 mm , 1.0 x Network - Generic - 34 pin IDC , 1.0 x Parallel - Line-out (side surround) - RJ-45 , 1.0 x Audio - Line-in - Mini-phone stereo 3.5 mm , 1.0 x Hi-Speed USB - Line-out (rear) - 9 pin D-Sub (DB-9) , 1.0 x Audio - Input - Mini-phone stereo 3.5 mm , 1.0 x Mouse - Ethernet 10Base-T/100Base-TX/1000Base-T - Mini-phone stereo 3.5 mm , 1.0 x Audio - 4 pin MPC
Apr 09, 2011 | Gigabyte GA-945GZM-S2 Motherboard
I have desktop computer with celeron processor CPU 240 GHz and 512 MB ram with 40 GB HArd disk.. I see my hard disk encountered some problem and planning to by new hard disk ..which is best for me and the...
Hi ,
I assume you are under Windows XP but this will also work under Windows 7 32 bit .
You can insert a 100GB HDD without any problem . A higher capacity is risky with your type of machine and could lead to a fatal read error , meaning you couldn't boot your unit anymore .
Under a 32 bit XP system , 2GB ram is the max.
I don't recommend changing the processor with the motherboard , you could encounter conflictual issues with the rest of the unit .
Buy yourself a new pc equiped with a I5 or better with a I7 processor running under W 7 64-bit is the solution but they still are expensive .
Best regards .
Jan 30, 2011 | eMachines Desktop / Intel Celeron...
My mothar board are pspe.vm so i know which ram add my mothar bord 512mb ya 1 gb ya 2 gb sopart my motharbord
ASUS P5PE-VM - motherboard - micro ATX - i865G specifications
General
Product type (AE)
Motherboard
Form factor
Micro ATX
Width
9.6 in
Depth
7.6 in
Pentium 4 , Celeron D , Core 2 Duo , Pentium D
64-bit Processor Compatibility
Yes
Mainboard processor socket
LGA775 Socket
Mainboard / Multi-Core Support
Dual-Core
Chipset Type
Intel 865G / Intel ICH5
Data bus speed
800.0 MHz
BIOS type
AMI
Storage key information
Serial ATA-150 , ATA-100
Power connectors
4-pin ATX12V connector , 20-pin main power connector
Processor
Installed Qty (Max Supported)
0.0 ( 1.0 )
Memory
Cache Memory Type
None
DDR SDRAM
Supported RAM Integrity Check
Non-ECC
RAM Installed ( Max )
0.0 MB / 2.0 GB (max)
Supported RAM Speed
PC2700 , DDR266/PC2100 , PC3200
RAM Features
Dual channel memory architecture , Unbuffered
Video
Graphics Controller
Intel Extreme Graphics 2 Dynamic Video Memory Technology 2.0
Audio
Audio Output
Sound card
Signal processor
Intel 865G
Audio codec
AD1988
Sound Output Mode
5.1 channel surround
Telecom / Networking
Modem
None
Networking
Network adapter - Marvell Yukon 88E8001 - Fast Ethernet , - Ethernet , - Gigabit Ethernet
Features
BIOS Features
SMBIOS 2.3 support , ASUS EZ Flash , WfM 2.0 support , ASUS MyLogo , Hyper-Threading Technology , DMI 2.0 support
Manual Settings
CPU frequency
Sleep / Wake Up
Wake on LAN (WOL) , Wake on ring (WOR)
Hardware Features
C.P.R. (CPU Parameter Recall) , Green Edition , CrashFree BIOS 2
Expansion Slots Total (Free)
1.0 AGP 8x - LGA775 Socket , 1.0 Memory - DIMM 184-pin , 3.0 PCI , 2.0 Processor
Storage Interfaces
Intel ICH5 : ATA-100 - connector(s): 2 x 40pin IDC - 2.0 device(s) , Intel ICH5 : Serial ATA-150 - connector(s): 2 x 7pin Serial ATA - 4.0 device(s)
Interfaces
1.0 x Audio - RS-232 - Mini-phone stereo 3.5 mm , 1.0 x Network - Generic - 34 pin IDC , 1.0 x Parallel - IEEE 1284 (EPP/ECP) - Mini-phone stereo 3.5 mm , 1.0 x Keyboard - Line-out (center/subwoofer)/line-in - 4 pin USB Type A , 1.0 x Audio - Line-out - 6 pin mini-DIN (PS/2 style) , 1.0 x Serial - Generic - 25 pin D-Sub (DB-25) , 1.0 x Mouse - Line-in - 6 pin mini-DIN (PS/2 style) , 1.0 x Hi-Speed USB - Ethernet 10Base-T/100Base-TX/1000Base-T - Mini-phone stereo 3.5 mm , 4.0 x Audio - Line-out (rear)/microphone - 4 pin MPC , 1.0 x Display / video - VGA - 15 pin HD D-Sub (HD-15) , 1.0 x Storage - Floppy interface - 9 pin D-Sub (DB-9) , 1.0 x Audio - RJ-45
Additional connectors (optional)
4 x Hi-Speed USB
Miscellaneous
Compliant Standards
RoHS , Plug and Play
Hope this helps,
If I have helped you resolve your problem, please
consider giving me a good rating and a quick
thanks or good job.It will help me as well Thank
you.
Oct 23, 2010 | ASUS P5PE-VM Motherboard
Upgrade processor, unknown socket type.
Here I have found the technical specifications for this system, but for informational purposes it is pentium 4 and celeron 478pin intel only. http://support.dell.com/support/edocs/systems/opgx270/en/ug/specs.htm
Oct 30, 2009 | Dell OptiPlex GX270 Small Mini-Tower...
851 MHz Celeron Processor
*********** board will support a max of 1GB of RAM. Your processor is an Intel at 1.8 GHz. The preceding is only true if your PC is the Emachines T1840 as you chose in the category listing of your post. Again if that is true, you can achieve the max RAM by installing a 512MB stick in each of the two memory slots.
Good luck.
PS: Gdlkn84as528 is correct in assuming that a less than 1.3GHz Intel processor would be a P3 or equivalent processor. So which is it, it can't be both ways?
Sep 18, 2009 | E-Machines -T1840-CELERON-1.8GHz,40GB...
More RAM wanted
Max is 256M Memory. You're much better off getting a new system. A new motherboard, processor and ram isn't that much...
Mar 16, 2009 | E-Machines eMachines Desktop PC
I have an eMachine T2240 with an Intel Celeron processor 2.20 GHz & 384 MB of RAM.  The only real complaint I have is that this machine runs slow - it is rather aged - and I tend to bump up against my...
Memory: Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot. You may purchase here.
This will give you the biggest speed increase.
CPU: I could not find specs for which cpus this motherboard supports. However, I had one of these same machines and succesffuly swapped out the celeron processor for a pentium 4 processor, 2.53 GHz. You should be safe finding a used processor on ebay that's a Pentium 4 2.2 GHz and it should work for you.
Thanks and please take a moment to rate as fixya.
Dec 12, 2008 | E-Machines T2240 PC Desktop
eMachines W3507  PC Desktop Logo
127 people viewed this question
Top eMachines Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
