Question about AT&T 1855 Phone
How do you set the answering machine or voice mail on this phone?
  • AT&T Master
  • 6,196 Answers
First make sure the answering machine is on; press the On/Off button to turn it on and off. To set a message to be heard by those calling in: press and hold Skip/Annc. Begin speaking when A shows in the message window. Speak from about 9 inches away from the phone. Messages must be more than 3 seconds and less than 3 minutes long.
Press Prog/Mem and then Skip/Annc to hear the current message. Press and hold Setup until you hear the current setting (Selected announcement is A or Announce Only). Use Skip/Repeat to change the setting. No one will be able to leave a message if Announce Only is on.
After you have held the Setup button, as above, press Setup additional times to set the number of rings before the machine answers and the remote access code among other features.
To set the date and time, press and hold Clock for 1 second. Use the Skip button to advance the current digit; the Repeat button will subtract one from the current value. Press Clock again to advance to the next value to change (day of week, hour, minute, second).
Press Play to hear new messages; press and hold Play to hear all messages. Press Repeat to repeat the current message. Press Repeat twice to hear the last message. Hold Repeat to slow the message playback.
Delete a message by pressing Remove during playback; press Remove twice to delete all messages (if there are no new messages). A blinking F indicates the memory is full and messages must be deleted.
I hope this helps.
(btw additional instructions for the answering system are available at the AT&T website. Direct link: http://telephones.att.com/documents/product_Product/219/UserManual/1982/1855_manual_bkm.pdf which may or may not work.)
Posted on Oct 29, 2010
Testimonial: "Wow, very detailed and in simple to understand English. I am programming my telephone right now. Don, Las Vegas, Nevada"
  • Cindy Wells Oct 30, 2010
    You're welcome.
Why won't the answering machine, when set to 'answer on' not record a message?.It goes to voice mail. Is my machine defective?
Maybe the answering machine is set to pick up at say"5 rings" and the voice mail is set to pickup at "4 rings" . Change the voicemail setting to a higher setting than the answering machine. That may be the problem.
Aug 26, 2014 | Lands Phones
How do I set up voice mail for my uniden 6.0 without answering system
If you do not have an answering system (answering machine) on the phone, you need to purchase a answering machine or contact your telephone service provider to get Voice Mail service from them. (Most charge $3-5 per month for voice mail.) The provider will tell you what number to call to set up a voice mail message and access messages.
I hope this helps.
(for most Uniden systems with the answering system, you need to turn it on and then access the system from the handset to set the out-going message and length of incoming messages allowed.)
Mar 18, 2013 | Uniden DECT 6.0 Cordless Telephone...
How to set up voice mail for a AT&T Speakerphone 945
The AT&T 945 isn't an answering machine. What make and model answering machine/voicemail system do you have on your phone line?
Dec 24, 2012 | AT&T 945 Four Line Intercom Speakerphone
Voice mail
The VTech 6041 isn't an answering machine. In order to set up voicemail, you first need a device capable of handling voicemail, such as an answering machine.
Jul 12, 2012 | Vtech Cordless 6041 Phone
Even though my answering machine indicates it is on, noone can leave a message.The response is that the mailbox has not been set up.Can you help? Thank you.I have had this system for quite a while and have...
A "mailbox not set up" message is coming from your telephone line voice mail system, and not from your telephone answeringmachine. What this means is that the voice mail on the phone line is picking up before the answering machine has a chance, and since the mailbox hasn't been set up it can't take any messages. So there are two things you'll need to do.
First, you'll need to set up your voice mail. You may need to contact your telephone service provider for setup instructions since not all systems are the same, but here's how it usually works. From your home phone, call your own number so you reach your voice mail. You should get the message that your mailbox hasn't been set up, and will be prompted for an access code to get to the setup menu. The access code is usually the last four digits of your phone number, and you'll be prompted to change it to something else as part of the setup. Through the setup main menu you can record your greeting and set up other options like the ring count before the voice mail answers. Set it for a number larger than the setting on your telephone answering machine. (I have my answering machine set to 4 rings, and voicemail set to 6.)
Step two is to verify the ring setting on your answering machine. Four rings is a common default setting, but it's adjustable on the phone. Most newer phones have menus that you access from the handset to set change settings, while older models have a switch on the base unit.
Once the mailbox is set up and you have your answering machine set to pick up first, everything will work as you want.
Aug 14, 2011 | Uniden DECT 6.0 Cordless Phone
Hi i have a samsung jey s8000 contract phone however i am unsure how to switch on my voicemail?
hi, if you can't use your voice mail, maybe you can use your answering machine in your jet itself... just configure your answering machine to simply answer all your phone calls, if you are busy.. it will record all callers messages...
it is actually the alternative for your voice mail..
to switch on your voice mail, if you prefer to use the network service. you may try the following steps.. 1. press settings.. 2. on your settings, select applications 3. on your applications, select all calls 4. on your all call settings, select your voice mail and input your voice mail service number.. 5. once finished, select save, and exit your settings menu.. 6. to check if it's working.. use another phone to call your number, but be reminded that if your built in answering machine is on, turn if off..
good luck..
Oct 07, 2010 | Samsung Jet S8000 Cell Phone
How do you set up the answering machine to answer phone calls when you are on the phone.
If you have a Panasonic voice mail system, you use the FWD/DND button, dial 2 and 107 or 115, whichever is your voice mail number and # (also 712-xxx-#). This is the instruction for a TA series system tied to a TVS or TVA voice mail system, so yours may be different.
Carl
May 21, 2010 | Panasonic KX-T7731 Corded Phone
We have a Uniden DECT1588 Series system that we have just purchased. We are connected to a Voice Mail Service through Bell. We can receive the messages from the answering service but the light on the hand...
OK. You have a phone set with an answering machine, yet you continue to pay MaBell for Voice-Mail. Is there any compelling reason. That was my feeling when I first read your question but I thought you might not like what I had to say, so I consulted the Uniden FAQ and here what they have to say.
If you Uniden phone has a digital answering machine, and you also have voice mail through your phone company, the message indicator light will not light up when you have a message in your voice mail system. We recommend you discontinue your voice mail and use the Uniden internal digital answering system.
Jan 04, 2010 | Uniden DECT 6.0 Cordless Phone ID
Can I use cordless phone answering machine even if I have voicema
You do not have to cancel the phone company voice mail service. You need to change the number of rings the phone uses to answer the voice mail.
For example, if the telephone company voice mail answers if 4 rings, set the telephone answering machine to answer in 3 rings or less.
Good luck.
[email protected]
Mar 03, 2009 | GE 27992GE5 Cordless Phone
VOICE MAIL AND FAX
The short answer is no. The JX200 will work with an answering machine because it "listens in" when the answering machine picks up a call. It can't "listen in" to voice mail, because the voice mail is handled by your phone service.
Mar 29, 2008 | Canon FAX-JX200
AT&T 1855 Phone Logo
503 people viewed this question
Top AT&T Lands Phones Experts
Marvin
Marvin
Jax Planet
Jax Planet
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
