Hi
Please follow the steps to print the fax log
To print the fax log from the device control panel
1. On the device control panel, press Setup.
2. Press the arrow key to move down to Print Report, and then press OK.
3. Press the arrow key to move down to Fax Log, and then press OK.
4. Press OK again to print the log.
Testimonial: "Answered within minutes - problem solved. Thanks a lot."
The
fax log or Journal is printed automatically after every 50
communications (tansmissions and receptions). If you want to print a
copy of the journal;
Select Fax mode and press <Information> icon on the upper right corner of the touch panel.
Press <Print Journal>
In case you get an error report,
An error report is printed whenever the transmission or reception has failed.
If Transmission result report is on, a report is printed every time so you have a record of whether it was successful or not.
Good luck and please rate me, thanks.
