Question about Motorola Mobility H550 - Bluetooth Headset - Black/Silver Wireless Headset
How to pair Motorolla 550 - Motorola Mobility H550 - Bluetooth Headset - Black/Silver Wireless Headset
Posted by sagheer916 on
Grand Canyon Tech
  • 3,866 Answers
Please allow me to help you with you Blue tooth head set.
Step 1
First power on the headset you do this by sliding the call button towards the microphone.
After a few moments, the indicator meaning the "light" will be steadily lit in blue to indicate the headset is good to go in pairing mode.
Step 2
1. On your phone press the menu button then locate connection or device "phones are diffrent" at this point you need to turn on the blue tooth on your phone.
2. The phone should find the Motorola H550
3. Select OK or YES to pair you headset with your phone.
4. Enter the pass key: 0000
5. Press ok
Hint: Once the phone is paired with the headset the indicator will flash blue.
Now if the unit does not pair then you might be using another unit with this phone so please make sure you disconnect all blue tooth units and try the steps again.
If you have any questions WE can help please get back with me.
Thanks for using Fixya.com "We have a solutions for everything"
I hope this solution was VERY HELPFUL!
Have a Great day
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Oct 29, 2010
Can the LG HBM 550 be paired a second time to another phone?
YES IT SHOULD BE ABLE TO BE PAIRED TO AS MANY PHONES AS YOU WANT BUT WILL ONLY WORK ON ONE AT A TIME.
Sep 16, 2009 | LG HBM-550 Wireless Headset
My Lg Decoy wont sync with my Motorolla bluetooth
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Jun 05, 2009 | T-Mobile 81339TMIN T?•MOBILE BLUETOOTH...
Pairing my motorolla bluetooth headset with my Sony Ericsson W810
switch n the head set, the blue light will blink continuously. in the phone menu go to as shown
menu----settings-------connectivity-----handsfree----new device---. then search and add it to the list . it will ask for the pass code which is '0000'. after that press ok and then start using the head set.
if things does go well you can switch off and on the phone and then repeat t above mentioned process.
Apr 18, 2009 | Opticon OPN 2001 Mobile Data Collector...
HELP....
Well my user manual for HBM-550 says:
Prior to using the Headset for the first time, you must pair it with a Bluetooth enabled handset.
With the HBM-550 off, press and hold the Pwr/End button for 5 seconds,
You will hear two short beeps and the LED indicator will flicker in red and blue alternately, when the divice enters Paring Mode.
Using your Handset, find the Bluetooth Menu and "search for" or "add" new devices.
Select "LG HBM-550" from the list of devices and pair it with your handset.
When asked for the pass/PIN code during the paring procedure, please enter "0000" (4zeros).
Once paring has completed successfully, you will hear a beep.
After paring successfully, be sure to "Connect" to the HBM-550.
If you want to pair with other devices in the future, the headset must be placed in pairing Mode.
If the HBM 550 is in "Paring Mode" for 3 minutes, without being paired to a device, the Headset will automatically turn off.
Aug 13, 2008 | LG HBM-550 Wireless Headset
Passkey
The passkey is 0000
Dec 25, 2007 | LG HBM-550 Wireless Headset
To connect N95 with bleutooth headset LG HBM-550
1st switch on bluetooth for both devices!
2nd go to your bluetooth menu in your phone
3rd click on pair devices
make sure that your phone is visible to other bluetooth device
4th select the device and click on pair devices!
its done!
Dec 08, 2007 | Nokia N95 Cellular Phone
LG HBM 550 with Chocolate
Here is the problem, what most of the people do with this LG HBM 550 is press the PWR/END button on the headsent and when the headset light turn on Blue they let the button go and try to pair the device, this is worng when light is flshing Blue only it is not in the pairing mode.
You need to press and hold the button on the head set for five second and when the light flicker red and blue alternately, now device is in the paring mode.
Using you phone when to pair this device it might ask, depending on you r phone setting for the PIN or pass code which will be "0000"
Try ,,good luck
Regards
Chinmay
Nov 22, 2007 | LG HBM-550 Wireless Headset
Motorolla H350 with Sony Ericsson W800
does it still day that it is connected on the phone sometimes the bluetooth on the phone shuts off then you have to tuen it back on eventhough your headset is still on.
Aug 28, 2007 | Motorola Mobility H350 Wireless Headset
Motorola Mobility H550 - Bluetooth Headset - Black/Silver Wireless Headset Logo
Top Motorola Mobility Radio Communications Experts
Relax
Relax
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
