Question about Makita 12 Volt Cordless Drill/Driver Kit
I have one Makita battery charger 7.2-14.4V Ref: DC1414F P/N 630388CO. My resistors R40 and R21 are broken. I want to know the electronic's values.
Posted by volinga2006 on
  • Makita Master
  • 7,733 Answers
Jvc subwoofer will not power up
you can get the value from this link..
http://www.doctronics.co.uk/resistor.htm
Nov 01, 2008 | JBL LC-S960 Car Speaker
Dc1414f charger does not work anymore how to get the charger back charging again
  • BEWARE ! In recent years, on marketing technical reasons loader print separately orderable significantly
    more expensive than a new complete charger with many brands.
  • Panasonic Festool Bosch Dewalt can have on a different base a Replacement powerprice , but sometimes most in the budget range its better to buy it complete new. its oft cheaper.
  • If On download page below the picture you see the word processing .... wait be pati?nt until there pop upped the word Get Manual underlined in stead of.
  • MAKITA DC1414F BATTERY CHARGER Service Manual free download schematics...
Apr 19, 2015 | Makita 6916fd Impact Driver & Dc1414t...
Hioki 3030-10 hitester resistor. R21 blown. Any kind soul have the value of R21?
If it is working why change it. I assume it is in calibration. package is not value related.
Jun 18, 2014 | Hioki 3030-10 Analog MultiMeter VOM
How can i fix my makita 18v battery
there is no fixing these batteries that i know of. they have an electronic chip in them among other electronics. the battery talks to the charger and vice versa. battery packs that can be worked on doesn't really save any money with all the aggrivation you go through.
Aug 31, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
I have a Makita with 2 PA14 batteries and a DC1414F charger. When I turn the charger one the green light flashes once but no other lights show at all when I'm trying to charge my 2 batteries. Neither...
You stated you have a 12V Cordless Drill with PA14 batteries. The PA14 battery is 14.4V. The battery may fit in your tool and might work for a while but the motor isn't made for that battery. The way to check the batteries is to try them in another charger, any 14.4V to 18V pod/stick charger will work. The way to check the charger is to try another battery, any good 7.2v to 14.4V pod/stick battery will work. Unless the charger got wet or extremely hot the problem is usually the battery. Just check to make your tool and battery voltage is compatable.
Aug 08, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
I have 110 volt durapro 18volt dc battery charger, component R14 has burnt out beyond recognition and I was hoping someone could tell me exactly what it is so I can replace it. Thanks
The component is a resistor. The problem is going to be determining the resistors value since it was burnt and you can not see the color code. You might try contacting the manufacturer and asking them the value of that specific resistor by including the number like you did in your post R14. If you can find a wiring diagram for the product, it should tell you the value of the resistor also.
I hope this helps you getting started in solving the issue.
If you would not mind, please rate my help. I would greatly appreciate it. Thank You
Feb 07, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
R40 piece is missing is that a problem
Hello crzykd129,
If a piece of a resistor has broken off, it's value has changed which affects other things in the circuit. It needs to be replaced with a new component to restore proper operation. The remaining portion is being severly overburdened everytime you power it on and it's just a matter of time until it causes some other part to fail.
Resistors are generic so try locating it by resistance value (indicated by the color coded bands), and wattage and replace it. Here's a source for all types of electronic components.
Hope this helps.
Aug 08, 2009 | Legacy Audio Blue Diamond LA1480 Car Audio...
Was given a Coleman power drill, model CMD8189. The charger is inoperable. The two resisters on the charger internal circuit board have been fried. The resistor codes have been burnt off, so I cannot
I need the same, but found a Makita multi-voltage charger and have been able to use it. The package says It is for Makita batteries only. HItachi also makes a universal battery charger. I found both at my local Lowe's. The Makita was originally $69, but was marked down to $25. The Hitachi was around $70. You can find either one for good prices on Ebay or Amazon.
May 05, 2009 | Coleman Cable Coleman 18 Volt Combo Drill...
Makita Battery Charger DC18 RA
Maybe your battery is died, you can replace it on
http://www.drillbattery.com.au/buybattery.php/makita_1220_power+tool+battery.html
Jan 20, 2009 | Hand Tools
Makita 12 Volt Cordless Drill/Driver Kit Logo
841 people viewed this question
Top Makita Drills Experts
efs_perpends
efs_perpends
epangan29
Mike
Are you a Makita Drill Expert? Answer questions, earn points and help others
