Cameras Logo
Posted on Oct 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Camera says battery not compatible - Sony Cameras
Anonymous
Level 1:
Guru:
  • Contributor 29 Answers
  • Posted on Dec 09, 2010
Anonymous
Contributor
Level 1:
Guru:
Answers
29
Questions
0
Helped
14136
Points
39
Maybe the battery is not the original battery.
you can buy cheap replaement batteries for your digital cameras.
US shop:
http://www.sales-battery.com/digital-camera-batteries.htm
UK shop:
http://www.global-battery.co.uk/digital-camera-batteries.htm
  • Anonymous Dec 21, 2012
    bought one ,really nice
DMS-UK
Level 2:
Scholar:
New Friend:
  • Expert 81 Answers
  • Posted on Dec 29, 2010
DMS-UK
Expert
Level 2:
Scholar:
New Friend:
Answers
81
Questions
0
Helped
25641
Points
179
Hi
If the battery is a Sony InfoLITHIUM rechargeable battery (rather than AA or AAA batteries) then the problem could be a communication issue between the battery and camera.
If the battery does not respond to the 'handshake' the camera sends it, the camera will shut down with a 'battery not compatible' message.
Non response could be down to a faulty battery, or the chip inside the battery not having upto date InfoLITHIUM compatible code.
You could buy a replacement battery from here
All batteries show which cameras they work with which should help you to find the compatible one you need
Anonymous
Level 3:
Guru:
  • Master 592 Answers
  • Posted on Oct 29, 2010
Anonymous
Master
Level 3:
Guru:
Answers
592
Questions
Helped
128845
Points
1820
If you are using standard rechargable batteries in the camera, some cameras will not allow you to use them. you must use sony or non-rechargable.
an example would be AA or AAA rechagables. They only have 1.2V at ful charge where a non-rechargable starts at 1.5V.
Also if your camera uses a battery pack and you are not using a sony, it may not be compatible because some batteries have chips in them as identifiers. With a missing identifier the camera will not use the battery to prevent damage. If you are using a sony battery they battery is probably damaged or the wrogn model
1helpful
When i turn on my Cyber-shot camara it always says " For use with compatible battery only." What do i do ?
sorry to say this friend....u have inserted an incompatible battery in your camera
that is why the message "for use with compatible battery only" keep showing up whenever u switch on your camera
so u got to replace your currently installed battery to the compatible battery of your model
so i have searched the web for your model's compatible battery list...just check with it in the below link
http://www.sales-battery.com/digital-camera-batteries/sony-cybershot-dsc-t100_r.htm
even check with your sony cyber-shot model's manual for compatible battery info
in case if you have lost your manual friend...below is the link for your model's manual download
http://www.pdf-manual.com/user-guide-instruction-owner-manual-sony-cyber-shot-dsc-t100-13434.html
"feel free to ask further help friend....am here to guide u based on cameras:-)"
1helpful
I have a sony dsc-t90 camera when i turn on the power there is error massage {for compatible battery use only}i change a new battery but the problem is still there so is there any body can help me what is...
The compatible batteries for this Camera are NP-FD1, NPBDL.
Please make sure that you're using compatible battery pack.
Remove and reinsert the battery pack, while the Camera is turned off.
Reset the Camera by removing the battery while the Camera is ON and reinsert the battery after a minute and turn on the Camera.
If the issue is not resolved the Camera needs to be serviced, as it will be the issue with the hardware part of the Camera.
Why does my olympus FE-270 digital camera drain battery really fast. i have used all types of batteries, but to no use
Link
Your camera might need a battery replacement. Make sure that the battery your going to buy is compatible to your unit. Kindly refer to above link for accessories, compatible to your camera.
God Bless.
Only for use with compatible battery
Try clean contacts of camera for battery, specially the middle one - it is for communication between camera and circuit inside the battery.
1helpful
Compatible Battery error message
Try clean contacts of camera for battery and contacts of the battery also, specially the middle one - it is for communication between camera and circuit inside the battery. If the problem persists, try use another battery in your camera, or your battery in other compatible product - you determine this way if the problem is inside the battery (I hope, it is cheaper) or inside the camera.
Battery compatibility error, even tho it came with camera!
Sony camera with correct sony battery saying battery not compatible
3answers
Fit my Canon NB-4L Battery
Canon nb-4l battery pack canon 100 percent compatible with you canon nb-4l camera battery. I bought two canon nb-4l battery from http://www.camera-battery.co.uk/canon/nb-4l.htm two weeks ago, I felt very surprised, because it fits nearly as good as the original battery.
Kodak Easyshare Z1285
Are you using the batteries listed as compatible according to the cameras battery door? Or are you using NON-compatible Alkaline or Ni-Cad batteries? Only Li-Ion and Ni-MH are compatible. Hope this helps...
1helpful
2answers
Battery Problem
I bought a SONY DSC-S750 3 months ago. Since last week, when i turn the camera on, appears the message "for use with compatible battery only". The battery came with the camera. The camera was bought in a big store in Philadelphia. I WILL NEVER BUY A SONY CAMERA AGAIN. I already tried to reset, tried to remove the battery and the problem persists.
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
