Question about Kenmore 9387x Top Load Stacked Washer / Dryer
How to remove an agitator from electric model C93872? If there is a removeable screw, is it a right or left hand thread?
Posted by erajjh on
4 Related Answers
Anonymous
SOURCE: Sears Kenmore 80 series washing machine Model 110.26832691
Model 11020922990 Kenmore Three speed is tearing shirts. Sear is no help at all. All they want to do is send a $75 service call or sell a warrenty. I just need an answer to the question, Why are my shirts being ripped up. The owners manual has some suggestion none of which fit this situation.
If I have to rely on Sear a rock at stream side sould like a better solution!
Posted on Jun 02, 2008
Anonymous
  • 115 Answers
SOURCE: Removing Agitator from Kenmore Model 110 Top Loader
How to replace Whirlpool/Kenmore washer
dual action agitator ratchet ‘dogs’, kit # 285770
Tools needed: Screwdriver, 3/8" drive ratchet wrench, 7/16" socket (older models), 3/8" drive to 1/2" adapter (newer models), long 3/8" drive extension, small amt liquid detergent
1) Pry the agitator cap off by inserting a screwdriver into the cap’s notch
2) Pull the inner cap (if present) off – most Whirlpool machines use this inner cap, with a handle, to gain access to the center bolt
3) Remove the bolt in the center of the agitator
(Earlier models used a 7/16" hex-head steel bolt)
(Recent models use a 1/2" square drive plastic nut – use a 3/8" X 1/2" ratchet adapter)
4) On older models, grasp the bottom portion of the agitator and pull the entire ***’y off.
(Recent models allow just the top portion’s removal to access these ‘dogs’)
5) Older models – place the agitator on the floor, and, standing carefully on the bottom portion, pull the top half off. Turn it over, and the dogs will be accessible for replacement.
6) Newer model dogs can be replaced once the ratchet ***’y is removed. There are several versions currently in use, but most can be replaced without removing the bottom agitator half. All‘4-dog’versions use the 285770 kit, regardless of the cam ***’y style. (Older agitators, rarely seen now, used a pair of 2 larger dogs, which are a different part number)
7) On older versions, be careful to align the two tabs when inserting the upper ***’y back onto the agitator bottom half. When these are aligned, they will friction-fit the two halves together, making it easier to reinstall the ***’y. Handle it only by the bottom half to prevent pulling the top half off when reinstalling.
8) Lightly lubricate the agitator cap’s rubber gasket using a bit of dishwasher detergent, and push it back into place. (On the Whirlpools with an inner cap, lube that cap’s o-ring too – makes it easier to snap into place)
9) Reach around and pat yourself on the back! You just saved at least $75.00!
Posted on Dec 31, 2008
Anonymous
  • 77 Answers
SOURCE: cant remove agitator. Fabric softener cap is off but i do not see a screw or bolt to remove the assembly. agitator is only weakly working
There should be a 7/16 bolt in the bottom of the cup once you have taken the cup out. Its kinda deep you would need a longer extension. Also this agitator bolt usually has a gasket material attached to it and it may be covered by another cap.
Posted on Apr 17, 2009
aborcass
Ron Coons
  • 2651 Answers
SOURCE: kenmore model#11023822100 does not have a bolt to
this isi a whirpool machine, however kenmore might change the agitator shaft slightly, sometimes there is a "nut" holding the 2 halves of ajitator together, tis can be loosened by using a 1/2" extension drive. this should release the 2 pieces. its defintly between the 2 halves, you may need to really pull it apart... itll go
Posted on Oct 09, 2010
Model ge whdrr418g, i need to remove the agitator. the fabric softener cup lifts off fine, but underneath is a smooth plastic area... every manual says to access the screw/bolt at the bottom of the center...
Hello:
You need to grab the agitator from the bottom( fingers under agitator in the tub) then kind of alternate puling up with your right and left hands.. There is no screw holding your agitator in place..it may seem like it doesn't want to let go at first but it will eventually..
Good luck
May 24, 2017 | General Electric Washing Machines
How do you remove the chuck from a dewalt 12 volt dw953 drill
Open the chuck wide open. In the center is a retaining screw, they usually have left hand threads. Remove the screw. Take an allen wrench 1/4" to 3/8" in size and fasten the short side tightly in the chuck. The chucks are usually right hand thread, so take a small hammer and strike the allen wrench to turn the chuck to the left to loosen it.
Apr 12, 2011 | Garden
Craftsman Model #315.271690 3/8 Professional Electric Drill (corded). What are the specifications (dia, threads per inch, etc.) of the left hand thread machine screw that holds the chuck on. The Sears...
How do you remove the chuck from a Craftsman Model #315.11441 3/8 vsr corded drill? Am trying to remove the chuck but I believe there is some type of a set screw or locking mechanism that needs to be undone. I can see a slotted screw head in the chuck Looking straight down on it but it is very tight and I don't want to break it or a screwdriver forcing it. Thanks for input. Bob
Sep 06, 2010 | Craftsman Drills
How do you remove a key chuck
Open the jaws all the way.
Peer inside, find the flat blate screw head. THIS SCREW IS LEFT HAND THREAD - NOT STANDARD RIGHT HAND THREAD.
Put your drill into a vice and snug it down gently. Put a flat blade screw driver bit into the slot. Tap the screw driver with a mallet several times. Try turning the screw driver as you tap gently. Once it breaks free, remove as usual.
With the locking screw out, put your key into the chuck and tap tthe key it to loosen the chuck. The chuck should be held onto the shaft with right hand threads ... some are different. Try each direction, gently, until you break it free.
I hope this helps you
Thanks for your question
Please vote.
Dec 15, 2009 | Office Equipment & Supplies
How to remove the keyless chuck from a hitachi dv18dl?
The screw mentioned in solution number one is a left hand thread once you have removed it use an allen hey in the hole the screw came out of as if undoing a normal right hand thread a scarp blow with a hammer may be neccesary. then do the opposite when installing new chuck
Nov 26, 2009 | Hitachi 18V Lithium Ion Cordless Hammer...
Need to remove the chuck on my 3/8 milwaukee drill. I opened the chuck and removed the screw in the bottom but can't get it off. does it pry off or unscrew? right or left hand screw???
if this is a cordless drill please review the tip section, if not the spindle has a hex that you can put a thin wrench on and the threads are standard meaning you would use a chuck key or allen wrench to hit it in the counter clockwise position to remove it. Let me know if you have any problems
Nov 23, 2009 | Milwaukee Tool Drills
Oven fan zannusi zbf360x
Remove rear panel in back of oven, there you will see the fan,remove fan blade,usually left hand thread, and remove screws that hold fan, if they are not accessable from inside the oven then you will have to remove oven from housing, and remove rear outer panel to access fan screws and connections.
Remove fan and replace in reverse order.,don't forget the nut that holds the fan is a left hand thread.
Plz rate this solution.
Thanks.
Dec 14, 2008 | Zanussi ZBF360X Electric Single Oven
Drill chuck removal
The screw should be left hand thread and the chuck is normal thread. The 'workshop' way to remove the chuck is to remove the screw (done). If the jaws are still working then clamp a sturdy allen key in it and whack it against a workbench to unscrew the chuck. If holding the drill in the normal position you would stand with the workbench to your left and whack it down on that. If the jaws aren't working then you can grip the body in a vice and use large pipe grips or stiltsons on the chuck. Also check to see if the chuck spindle will accept a thin spanner to hold it, as this is a slightly more caring way to brace the spindle. Then you can can hold the spanner in the vice and use the allen key in the chuck and unscrew it that way.
Oct 22, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Dewalt dc920 repair instructions chuck
To remove the chuck on your drill follow the instructions for the type of drill chuck you have:
Instructions for removing a keyed chuck
Most reversing drills have a left hand threaded screw located inside the bottom of the chuck.
1.) If the unit has this screw place the chuck key, with the chuck facing toward you, into one of the holes on the right side of the chuck. Strike the key in a clockwise direction with a wooden mallet or similar object. This will loosen the screw inside the chuck.
2.) Open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
3.) With the chuck facing toward you place the key into one of the holes on the left side of the chuck. Using a wooden mallet or similar object, strike the key sharply in a counter-clockwise direction. This will loosen the chuck so that it may be unscrewed by hand.
There is no way to stop the motor from turning.
It may require several attempts to loosen the chuck
Instructions for removing a keyless chuck
1.) If the unit has this screw open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
2.) Insert the short end of a 1/4" or larger hex Allen wrench into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard right hand thread. This will loosen the chuck so that it may be unscrewed by hand.
Oct 15, 2007 | Dewalt 18 Volt Compact Drill Kit
Kenmore 9387x Top Load Stacked Washer / Dryer Logo
Michael Thomas
Michael Thomas
Harvey Mahal
Tracy
