Question about Yes PDV91 9 in Portable DVD Player with Screen
I have bought this DVD player in Tenerife, but after playing a few DVD's I have no sound anymore from the speakers and no sound from ear-phones. Last week I went back to the shop for repairing under warranty, but I need to wait more than one week. This was not possible because I was only for one week on holidy in Tenefife (I am from Belgium). Because they tell me it must be a broken wire inside on the phone connection and I need to do it by myself. I have opened it, but no wire was broken. Is it possible a software problem or what can I do to fix it, thanks.
Posted by pierrevancau on
Anonymous
    New Friend:
    Problem Solver:
  • 4 Answers
...be sure you are in the same zone as the DVD was designed for. The world seems to be divided in numerous zones, and DVD'S from one area will not work from another area. That is why one should not buy equipment when one goes on vacations !
Posted on Oct 29, 2010
  • pierrevancau Oct 31, 2010
    The sound on the DVD player has worked several months, but last week it don't work anymore. In the earphones the music is very qired (very low)
Philips portable 9"DVD player
Sounds like the headphone socket is faulty. I would get it repaired under warranty.
Jul 18, 2017 | Philips PD9030 9" LCD Portable DVD Player...
No sound from speakers
insert the ear/head phone in backpanel sound pin (Green color),
1.if You can hear the sound in ear/Head phone,then the problem is in the speaker.replace the speakers
2.if You can't hear the sound in ear/Head phone,then the problem is in your system audio driver.So Down load the audio driver which is suitable for your system and install it.
Feb 13, 2010 | Insignia 2.0 Speaker System (2-Piece)
Shinco Portable DVD SDP-1731A - Sound not working.
I have had a couple of these with the same problem , and in 2 out of the three cases the cure was the same .. Earphone socket fault ?
Ear phone sockets are designed to dissconect the speakers on insertion but with the constant use and pulling they get on a mobile system they sometimes lock open and do not reconnect the speakers you could check that ..
The other one I had was diffrent that one the sound output chip was faulty and had to be replaced as did the speaker output capacitors , one had failed causing the chip to overheat .. hope this helps Regards Vortash
May 12, 2009 | Shinco SDP-1730 Portable DVD Player
Car DVD player will only play sound through wireless headphones, not through speakers
We have a GMC Envoy which also does not allow us to play the sound from the dvd player through the car's speakers. Although we purchased the vehicle new with the dvd player already installed, it was installed by the dealer, making it after-market. I assume those that were installed in the factory work differently. Maybe this is the case with your's as well. Good luck!!
Aug 01, 2008 | Nesa Vision Car Audio & Video
Plays a few minutes then stops, and will not play any dvd
ITS THE MOTOR ITS FREEZING ON YOU NEEDS TO BE REPLACED
Jul 01, 2008 | Fusion DVD-811 DVD Player
NO sound
if you mean, no sound when playing a disc in the player, you may not have connected the audio lead into the back of the player to the CD1 connector on the motherboard, likewise, you may not need to connect it if you have, as some of the latest dvd players play the sound through the ide cable to the motherboard onboard sound, which may cause problems if you have a seperate sound card fitted. You can also run this to check drivers, click start>run, then type 'dxdiag' and press enter and go to the sound tab to check for faults
Jun 02, 2007 | HP LightScribe dvd640i (DVD640I)...
Yes PDV91 9 in Portable DVD Player with Screen Logo
109 people viewed this question
Top Yes Televison & Video Experts
Marvin
Marvin
NOEL
NOEL
ray gallant
Are you a Yes Televison and Video Expert? Answer questions, earn points and help others
