I would say you have a bad jazz board,do this open the right hand side door of the fridge,you'll see on the touch pad the up and down arrows,hold the light switch in and press the down key three times,let go of the light switch press the down button again and i think it says like s and p can't remember but press the down one more time and you should see 4 and 4 or whatever settings you had if you see this close the door,open the freezer, by doing what i told you you manually put it into defrost,if you hear the compressor running the board is bad part WPW10503278 and i have to tell you i've changed quite a few of these boards.also if the strip between the doors are hot check you coil on the bottom,usually when this happens the condenser coil is blocked with dust or the condenser fan isn't blowing,if you ever find the fan not blowing you can get a house fan and blow it onto the compressor and coil this will keep it cool until you change out the fan motor and you won't loose any food but that's another day.your coil might just need to be cleaned or the jazz board could be causing this because the compressor is running longer than it should.if you unplug the fridge,melt out all the ice off of the coil as best you can but the more the better you'll be able to use the fridge like normal for like 10 to 12 days then the coil will freeze up again so order the board melt out the ice with a hair dryer and you should be fine,if you need a hand programming the new board let me know i would tell you how to do it but i don't know if people are getting my answers nobody writes back,so open the freezer door,open the right side door,hold the light switch in,push the down button three times,let go of the light switch and push the down pad again and one more time you should see settings again,close the door,if compressor is running the board is bad.
https://www.youtube.com/watch?v=HUoGLZYv...
one more thing if you remove the bottom kick plate there should be a tech sheet either folded up and it's in the kick plate or it's in a plastic pouch taped up to the floor check right side but could be on left too and clean the coil while you're down there
https://www.youtube.com/watch?v=aqptKoBx...
for some reason the other video isn't working that i sent up above.go here and see how to remove board.
SOURCE: JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
SOURCE: Freezer/Fridge work SOMETIMES
Sounds like you have a bad relay on the compressor or a bad compressor. If the compressor is a Tecumpseh brand then it is most likely the problem.
SOURCE: Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
SOURCE: freezer is not cooling at top - ice melted -not
Check the back wall of the freezer for a ice buildup.(failure to defrost)
Check the freezer fan motor. Is it running?
SOURCE: drain hole under the evaporator coil in freezer keeps icing up
The drain may be clogged or running slow, flush some very hot water down the drain opening using a turkey baster or syringe. Here is some information I put together on drain freezing and how to clean them out in a little more detail. Let me know if this works for you. Thanks
http://www.fixya.com/support/r4686046-water_leak_from_freezer_ice_freezer
