SOURCE: HP vs 19 Flat Panel LCD Monitor will not turn on.
I too have an HP vs19 lcd monitor that the power stopped working around 18 months of use.
I have been searching trying to find a website that maybe someone had taken photos of their repairs on these vs19 lcd monitors.
Haven't found a site yet.
I would like to know before I attempt to open up the back of my monitor, the capacitors you are speaking of, are these soldering or do they just plug into the power board?
I'll be hitting the radio shack to see if I can get these capacitors.
SOURCE: monito going to sleep
I have the same problem. Monitor states going to sleep and the pc goes dead
SOURCE: no sound from speakers
Ok newer monitors come with a HDMI connector and would need a compatable HDMI video card that has the ability for sound. The older monitors have a 3mm plug like a head phone jack you can plug this directly into the GREEN portion of the sound card that is installed in your system!
Thanks please rate
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: I have a HP vs17 monitor that keeps going to
I assume you have already tried this monitor with other PC and get the same result, just want to narrow down the problem before taking thing apart.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP and other monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
