Question about Stanley Fatmax Xtreme Retractable Utility Knife
I can't open or refill the fat max. Lost the instructions.
Posted by don1samuels on
Anonymous
  • 760 Answers
If it is a 10-816 then Knife swivels open for easy blade change and clean out - no tools required, much like 10-999
If it is a 10-778, you don't really open it. You press little button on left side, behind the blade wiper, and this releases blade. Push red button on rear of knife, to open blade storage
if it is a 10-999 then press the button on rear and rotate the two halves.
Posted on Oct 29, 2010
  • piper1313tod Jan 17, 2011
    To load @unload blade's on the Stanley FatMax Model# 10-778 push the blade wiper all the way to the front. then you push the black button on the right to unlock and then on the left side at the very front there is a little black button push that and the blade's will go in you may need to work it up @ down a little to get to go in, ; Anonymous"
Where can I get instructions forStanley Fat Max 700 jump starter j7csr user manual
http://media.wix.com/ugd/217982_8aaa2b786e2a4579baf84c342011767f.pdf
The only difference between this model, and the j7csr is this:
  • Bonus Priority Auto Assistance road-side service
Roadside Assistance program information and activation are included with the Jumpstarter. Whenever you travel, you'll like the secure and confident feeling of knowing that you are protected by Priority Auto Assistance.
12 Month Membership Includes:
24 hrs Emergency Roadside Assistance, 24 hrs Towing Service, 24 hrs Mechanical First Aid, 24 hrs Tire Change Service, 24 hrs Emergency Delivery, 24 hrs Emergency Battery Service, 24 hrs Lost Key Service, Rental Car Discounts, Map Routing Service and Theft/Hit & Run Protection Services
Feb 11, 2015 | Hardware & Accessories
Scale BFM588 User manual
Although the HealthOMeter.com site no longer posts a user manual for the BFM588DQ-81 scale, they do have a different model scale, BFM955-60, instruction manual that will work for the BFM588 because all the setting buttons are identical. You can download the manual for free at their site. Go to the site, under "Service & Support" setect "Instruction Manuals", then select "Body Fat Scales". Once there, find and select the BFM955-60. It will open as .pdf document and you can save it to your computer and print it out. It worked for my BFM588 scale for which I had lost the user manual.
Nov 16, 2014 | Health-O-Meter Health o Meter BFM588DQ-81...
I used my Stanley Fat Max 450 Amp Jump Start System with Compressor 900 Peak Battery Amps to jump start a vehicle and accidently crossed the negative to the positive and positive to the negative. After...
I would imagine an item from a company such as this has a fuze or such to prevent damage from cross connection. The pop you heard is probably an internal fuze or overload unit going off.
They are online at samsclub for 39$ if you can't fix it.
Jul 21, 2014 | Cars & Trucks
How do you replace the battery on the 7544BL Cal-Max Scale
How do I replace the battery in my Taylor 7544BL Cal-max scale.
We removed the back and the lithium battery is positioned oppisite the opening?
May 07, 2013 | Taylor New 7544bl Biggest Loser Cal-max...
How to open to get water inside
No need to open iron! You just unplug the iron. Hold the iron upright. Using a clean cup, pour water into the "open" WATER FILL HOLES just above or in front of the Temp. Select Dial. Watch the water window on the left. When water level reaches MAX, you are filled. Plug in and use. Refill as needed. Ref. - Page 8 in the instruction pamphlet.
Oct 18, 2009 | Black & Decker Quick N Easy X420 Iron
Lost instructions for bmi and special feature settings
Conair Support – Online Tech Help to Troubleshoot Problems
by: Guest1223497 in Conair Weight Watchers WW-87 Body Fat Glass Scale | 9 months , 28 day(s) ago | 10 ... Manual or Instructions for Conair CID502 Phone ...
livesupport.maybenow.com/Conair
Oct 04, 2009 | Conair Weight Watchers WW-87 Body Fat...
Gta cheats
hi there,
try this for gta 2 sandreas
Health and Stats
$250,000, full health and armor - HESOYAM
Infinite Health (no damage from bullets, melee attacks, and fire) - BAGUVIX
Commit Suicide - GOODBYECRUELWORLD
Hitman Rank and Perks in All Weapons - PROFESSIONALKILLER
Infinite Ammo - FULLCLIP
Infinite Lung Capacity - CVWKXAM
Jump Higher - KANGAROO
Jump Higher on BMX - CJPHONEHOME
Lower Muscle/Fat Stat - KVGYZQK
Max Fat Stat - BTCDBCB
Max Muscle Stat - BUFFMEUP
Max Respect Stat - WORSHIPME
Max *** Appeal Stat - HELLOLADIES
Max Stamina - VKYPQCF
Max Vehicle Stats - NATURALTALENT
Apr 22, 2009 | Computers & Internet
Fat max laser is in inches need feet
Press and hold the "+ - units" button and hold for over one second. It should then let you select your units of measure. In this case it should be the second selection, which is "0.00 ft". If you lost your owners manual, you can download one at www.engineersupply.com/Manual-and-Help-Docs/Stanley-TLM100-Manuals.pdf. If you find this helpful, please rank the solution.
Mar 11, 2009 | Grip On Tools Stanley& Fat Max Tape...
Lost instructions
I also have lost the instructions to this refill kit. Where do I drill the hole?
Feb 27, 2008 | Nukote Nu-kote RF196 Black Refill Kit
Stanley Fatmax Xtreme Retractable Utility Knife Logo
692 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Vernon Taylor
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
