Question about Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
If your water has NO hot water, then click circuit breaker
Next, click red reset button.
Turn off power.
Open cover on water heater.
If heater has 2 covers, open top cover
After re-seting water heater, insulation must be put back over thermostat to prevent cooler air from affecting thermostat.
1) Reset button is a good starting place to check water heater.
Reset clicks off for a number of reasons, including overheated water.
2) Reset will not reset, then replace thermostat.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
3) Resets clicks on, but clicks off again later, you should diagnose the problem.
Clicking reset is not a hazard
Click the reset as often as you want until you have time to diagnose.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
4) Reset is not tripped, and you still do not have hot water:
Then use tester on top two screws (T1 - T3 screws -or- 1 and 3 screws) of upper thermostat to check if you have power.
If you have power, then replace thermostat.
If problems continue, a full diagnosis is needed as per the link above
If you need more help, add a comment and I will respond
Posted on Oct 29, 2010
Apr 20, 2018 | Rheem Water Heaters
Dec 26, 2015 | Water Water Heaters
Jun 13, 2015 | Water Water Heaters
Jun 15, 2014 | Water Heaters
Oct 10, 2012 | RHEEM 30 GAL ELEC TALL Water Heater 6YR SC...
Nov 14, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
May 16, 2010 | Rheem Tankless Hot Water Heater...
Oct 09, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Mar 05, 2013 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
539 people viewed this question
