Question about Texas Instruments TI-84 Plus Calculator
I want to graph a parabola on my ti-84. i entered the equation in y=, and then i turned on plot on, then i hit graph, but it is showing invalid dim. help please?
Posted by bhaavya10 on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
You're trying to graph a function that does not involve stat plot features but the calculator probably thinks you are. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Posted on Oct 29, 2010
When I plug an equation into the y= and hit graph it says there is an invalid dim
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Nov 07, 2013 | Texas Instruments TI-84 Plus Silver...
Fix the ERR:INVALID DIM message on my TI-84 plus, please.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd, STAT PLOT , and
Mar 26, 2012 | Texas Instruments TI-84 Plus Calculator
How do I get rid of the ERR: INVALID DIM message?
You're trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
So on my graphing calculator i put my equation x^3-x^2-10x-8. then i hit graph and it says err:invalid DIM.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd then stat plot, and then select 4:PlotsOff. By the way it is easy to graphing function y=x^3-x^2-10x-8.
See captured images: full graph and detail of the left side max
As you can see this function have zero values in the points -2, -1 and 4
Mar 04, 2012 | Texas Instruments TI-84 Plus Silver...
TI-84: trying to graph an equation and ERR: INVALID DIM shows up only PLOT 1 is highlighted Window XMax XMin Ymax and Ymin are correct Any ideas? Test tomorrow
Jan 05, 2011 | Texas Instruments TI-84 Plus Silver...
My TI-84 calculator keeps saying "ERR:INVALID DIM" whenever I try to graph a function. I have used many different equations and tried to reset the scales and stuff in the "WINDOW" but it keeps saying the...
One of the statistical plots is turned ON and you must turn OFF all the STAT PLOTS.
To do so
  1. Press [2nd][Y=] to access the stat plot configuration.
  2. Select [4:PlotsOff]
  3. Command PlotsOff echoes on main calculator screen
  4. Press [ENTER] to execute it.
  5. Return to your [Y=] screen to define functions to graph.
  6. When finished entering functions press the [GRAPH] button.
Aug 31, 2010 | Texas Instruments TI-84 Plus Calculator
ERR: INVALID DIM (That's the error message I receive every time I try to graph an equation)
[2nd][MEM][7:Reset][1:All ram][2:Reset] [ENTER]. Screen shows RAM cleared. Clear the screen and use [Y=] to enter the functions you want to graph.
Hope it helps.
Sep 27, 2009 | Texas Instruments TI-84 Plus Calculator
Graph and trace buttons don't work
This is probably because you have the stat plot on. You would need to go to y= and then go to the top where it says stat plot 1 and un highlight it if it is highligted. That should fix your problem.
Sep 16, 2008 | Texas Instruments TI-84 Plus Silver...
If either error occurs when trying to graph a function (not a STAT PLOT), the error can be corrected by turning off the STAT PLOTS. The following steps will turn the STAT PLOTS off, allowing the graph of the function to be displayed.• Press [2nd] [Y=] to access the STAT PLOTS menu.
• Select 4: PlotsOff.
• Press [ENTER].
• Try graphing a function like y = x^4-3x^3+6x-1
Jun 03, 2017 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
373 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
