Question about Pentax ZX-50 35mm SLR Camera
The mirror inside the camera has flipped up and wont stay down I can't see anything through the viewfinder
Posted by audreylew285 on
Bill Coan
  • 49 Answers
The ZX-50 does not have a mirror lock up feature so there are several possibilities for the problem. There could be residue on the foam padding where the mirror hits the inside of the camera frame causing it to stick. In this case the foam may need replacing and the inside frame cleaned. Checking with a camera dealer in your area will answer the question in more detail.
Posted on Oct 28, 2010
Why is my camera taking picture in reverse through the viewfinder?
This sounds like a mechanical problem inside the camera. If it has a flip-up mirror behind the lens, for example, the mirror may be stuck in the up position. Have it serviced by a qualified technician.
Camera not working
Hi Jane,
When we press the shutter release the mirror flips up after the shutter opens and closes the mirror flips down. When it flips down we then see out the viewfinder.
At first blush is sounds as though the mirror flipped up but not back down. Remove the lens look inside the camera press the shutter release what happens?
Cordially,
I have a Nikon d50, had it since 2006, I took a picture, heard a weird noise, and now the viewfinder is dark as if I have a lens cap on (I don't!) I took off the lens and saw inside the body of the...
Inside the camera is a mirror which reflects the scene up to the viewfinder. It flips out of the way when you press the shutter button. When the mirror flips up, the shutter opens and exposes the sensor. When you look inside, if the mirror is stuck in an up position, you will not see anything in the viewfinder. However, the mirror is super delicate....do not touch its surface or try to force it.
The view finder darkens every time i take pictures
That's how a DSLR camera works. When you are setting up the shot, the image through the lens is reflected by a mirror up to the viewfinder. When you snap the picture, the mirror flips out of the way so the image can be registered on the sensor and then the mirror flips back. So, for that time, there is no image in the viewfinder.
2helpful
I have an olympus om-1 and the viewfinder is black. how can i fix this? I had it in my camera bag safely and today i took it out and loaded it and the viewfinder is black.
Make sure the mirror lockup switch is not activated. Take lens off camera, look inside camera through lens mount and make sure mirror is in down position. When the morror is up, it blocks everything in viewfinder.
2answers
My nikon fg 35mm when i looked through the viewfinder it appeared to be evwerything black so I took the lense off and pulled the mirror down but the mirror wont stay there it keeps going back up, what can...
Mirror lock up usually occurs when the batteries are dead.
Try replacing them, and NEVER pull down the mirror manually as you risk breaking the camera (if you have not done so already).
4helpful
Olympus E410 viewfinder problem
As far as I am aware, you can use the viewfinder OR the live view, but not both at the same time.
This is because a mirror has to flip up out of the way to reveal the sensor for the live view to work, and the mirror needs to be in the down position to reflect the image into the viewfinder.
Switch between the two modes and double-check if there is a problem.
Also try removing the lens from the camera and checking the position of the mirror. It could be that it has got stuck in the up osition.
Hope this helps!
1helpful
Pentax ME Super Shutter and Rapid Wind Button...
anmolag,
it could be the rubber bumper next to the fresnel lens has become sticky. very gently ( after removing lens ) try to bring mirror down without forcing it. it should release easily.
if not, rotate the select knob off auto. open film door and check that the shutter is fully deployed, shutters should not be overlapping.
remove screws from bottom cover and remove cover, keep camera up side down so that re-wind button stays put. there is a locking lever under the take up spool ( gray ) . with a pin move lever toward film door and bring advance lever fully to the right , then let it go so it returns quickly.
the shutter should have fired. if not the camera will need to be repaired. get an estimate first as there are no new parts available.
1helpful
2answers
Nikon FG shutter
By "stayed up", do you mean that the mirror remained in the up position so that you could not see anything in the viewfinder or do you mean that the shutter actually remained open? I do not remember the exact features on your camera, but in general, this is what I would do.
1) Remove the film from the camera and take a picture. Note if you see anything in the viewfinder. If you see nothing, the mirror is in the up position. Verify this by removing the lens and opening the door on the camera back. Look through the lens hole. If you can see through the rectangular hole at the film plane, the shutter is open. If instead you something is obstructing the hole, the shutter is closed. In any case DO NOT TOUCH THE SHUTTER! The shutter is what is covering the hole.
2) If the mirror is in the up position, check to see if your camera has a feature that allows locking the mirror in the up position. Some cameras have this feature to allow use of lenses with very short focal lengths. If this is the case, simply unlock the mirror.
3) If the shutter is the problem, your shutter speed may be set to "T", which stands for time. In the time exposure mode, you press the shutter release once to open the shutter and a second time to close the shutter. Cameras with a "T" setting also have a "B" setting, which stands for bulb. This is a throwback to the old days when it was common to use air-powered shutter releases rather then cable releases. The bulb was a rubber bulb that you squeezed to force air through a tube and push a pin to activate the shutter. The "B" setting keeps the shutter open as long as you hold the shutter release in, but as soon as you take your finger off the shutter release, the shutter closes. Both of these settings are used to make timed exposures. If you find that the problem was that the shutter was set to "T", set the shutter speed to 1/25th second or so and try again. The following sequence should occur; the mirror will flip up and the viewfinder image will disappear, the shutter will open for the prescribed time and close, the mirror will return to the down position and you will again see through the viewfinder.
If this does not work, you may need to take it in for repair.
Pentax ZX-50 35mm SLR Camera Logo
Top Pentax Photography Experts
Ekse
Are you a Pentax Photography Expert? Answer questions, earn points and help others
