Question about Indesit 23 in. DV62 IX Built-in Dishwasher
No water entering the dishwasher - Indesit 23 in. DV62 IX Built-in Dishwasher
Posted by peter_har124 on
D. Floyd Kolb
  • Indesit Master
  • 43,501 Answers
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Oct 29, 2010
My 363.1522* dishwasher is not filling with water. the unit runs, but no water is entering the washer during the cycle.
Here is a tip that will help you to find out why water will not come into the dishwasher...
heatman101
Sep 07, 2010 | Kenmore 24 in. 15222 / 15229 Built-in...
No water enters the dishwasher when its turned on
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
May 23, 2010 | Bosch SHV46C03 Built-in Dishwasher
No water in the dishwasher
There's no water entering the machine If there's no water entering your dishwasher, check these:
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Jul 01, 2009 | KitchenAid KUDU03FT Built-in Dishwasher
Water not going into dishwasher
Water Inlet Valve
Float switch
Hope i helped you.
Thanks for using "Fixya".
Jul 01, 2009 | Maytag Dishwashers
No water
Water-inlet valve
Float switch
thanks and please do not forget to accept the solution
Apr 03, 2009 | Tappan MDB531RF Dishwasher
Water not coming into the dishwasher.
Water-inlet valve
Float switch
Water-inlet valve
Float switch
good luck......
Mar 28, 2009 | GE Dishwashers
Dishwasher not filling all the way,
hi,
Water-inlet valve
Float switch
Water-inlet valve
Float switch
good luck.........
Mar 28, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
No water is entering the Exxcel auto option dishwasher
hello there,
1. Water-inlet valve
2. Float switch
Water-inlet valve
Float switch
thanks for using FixYa
Jan 28, 2009 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Ariston dishwasher
Water-inlet valve
Float switch
Water-inlet valve
Float switch
Mar 01, 2008 | Ariston Technologies LI640S Dishwasher
KENMORE DISHWASHER WATER DOESN'T SPRAY.
Water-inlet valve
Float switch
Water-inlet valve
Float switch
Dec 05, 2007 | Kenmore 24 in. 15173 Stainless Steel...
Open Questions:
See all Indesit 23 in. DV62 IX Built-in Dishwasher Questions
Indesit 23 in. DV62 IX Built-in Dishwasher Logo
Top Indesit Dishwashers Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
