Question about Hotpoint FFA70 Bottom Freezer Refrigerator
Icing of freezer compartment. compartment freezes and pushes doors open.
  • Hotpoint Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 28, 2010
2 Suggested Answers
roberta3fan
  • 574 Answers
SOURCE: ICE GATHERS AROUND THE DOOR OF THE FREEZER COMPARTMENT
very possible the door seal is bad. Take a dollar bill and close it up in the door and see if has some resistance when you pull it out if not the seal needs replacing.
Posted on Jan 25, 2010
jamesfran536
  • 30 Answers
SOURCE: MY ICE MAKER MAKES ICE
Unplugged, Then allow 1 or up to 5 hour then open, if not get screw to open the compartment door. check all side of the compartment door. avoid so much full content to your ice maker refrigerator, and always give a free space to the compartment door.
Posted on May 26, 2011
Contents of Lg fridge freezer gone soft, ice had melted & hasnt renewed ice even after express freeze, it's definitely not at the temperature stated on the control panel
Open the top freezer drawer and look for ice build-up in the back of the freezer compartment preventing the door from closing all the way. If so, you have to defrost it. This is where your ice maker fan is, so it may be ice-bound and that is way the ice is melting.
Mar 11, 2017 | LG Refrigerators
Whirlpool Refrigerator Model No. WRN28RWG6
if the flap was open then truely excessive cold air is coming out/escape from the freezer causing no freezeing. you need to defrost your fridge.
Note also that frost build up increases time to freeze your food on the freezer. it also causes your fridge an increase in electricity consumption.
defrost your fridge for some time ti remove the frost build-up.
Nov 19, 2007 | Refrigerators
Is it worthwhile getting my fridge/freezer repaired?
with the condition as you described, I would consider junking it as the water will freeze and do it all again and any repairs would be good money after bad.
May 05, 2015 | Refrigerators
Ice maker problem
Try empty tray and see if ice has froze on any area if not buddy hire a tech it may be electrical component of the ice make
Dec 11, 2013 | Amana / AFI2538AEW
Underside of ice bin freezes up built up with frosty ice, dispenses no ice. numerous times we have defrosted with blow dryer, removed, cleaned bin, replaced; cleaned out ice that was built up in lower part...
W10224328 Dispenser Door Spring
The chute door is the reason your ice bin is freezing up and also the chute door being open draws warm moist air inside your freezer compartment causing massive amounts of frost and keeps the compressor runing all the time between defrost. You really n eed to get the chute door fixed. What is the correct model number? For the model KSRX25FT dispenser parts click HERE The chute door spring may be broken but you will not know untill you open the dispenser housing. I'm here should you post the correct model number or have questions, Sea Breeze
Oct 17, 2013 | KitchenAid Architect ® Series II KSRX25FT
Can I remove the freezer compartment from my Haier HSE12WNAWW?
not possible to remove the freezer
the most likely [problem is that the seals around the freezer door are not sealing properly
that allows the atmosphere into the freezer and the humidity then freezes and turns to ice , causing the problem
adjust the door and change that door seal
when defrosting the freezer, remove all the frozen food, and place a fan at the open door
atmospheric temp air will defrost a badly iced freezer in around 1 hour with the use of the fan on high speed
Apr 05, 2017 | Haier Refrigerators
MY ICE MAKER MAKES ICE BUT FREEZES UP AND TRHEN I CAN'T GET ICE OUT. I TRIED TO OPEN UP THE FREEZER COMPARTMENT BUT I CAN'T GET THE COMPARTMENT DOOR OPEN. HOW DO I GET THE ICE MAKER DOOR OPEN. I...
May 26, 2011 | LG LFX25971ST Bottom Freezer French Door...
Water pools and freezes at bottom of the freezer. When tray is full water leaks out of freezer onto kitchen floor.
I am uncertain as to what you mean by "when tray is full"? However, you probably have a clogged drain in the freezer compartment. During the defrost cycle, which usually occurs every eight hours, defrost components (defrost thermostat & heater(s) ) melt the ice that has accumulated on the evaporator coil in the freezer compartment. The water from the melted ice drains through a hole in the freezer compartment (behind the freezer's rear panel) and accumulates in a drain pan below the refrigerator. This water should evaporate over time, whereby you should not have to regularly empty the drain pan. If the drain hole is clogged (usually from algae or other debris, etc.), the water finds another path to flow (which is inside the bottom of your freezer compartment). This water will usually freeze. Water will then flow toward the front of your freezer compartment and out of the door on to the floor when you open the door.
Contact an appliance service company to unclog your freezer drain. Also have them check your defrost components (thermostat & heater(s)).
Feb 15, 2010 | Frigidaire Refrigerators
Older model fridge freezes on the refrig. side
check the damper door and see if its iced up this is between the refrige and freezer compartments and lets cold into refrige from freezer,if it ices up in the open condition the refrige control cant change the temp,defrost the door and then see if the control moves the door,if so also check the door seals to make sure they are sealing good so as not to let warm air in that can condense and freeze things like the damper door
Jan 16, 2010 | Refrigerators
My Whirlpool side by side keeps freezing on the regular side.
your damper door is most likely frozen in the fully open position,thaw it out if iced up,then adjust cold control to see if it closes,the door is inside between the refrige and freezer compartments,also if this happens again check the door seals to make sure they are sealing good and not letting in warm air that can condense and refreeze this door
Jan 16, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hotpoint FFA70 Bottom Freezer Refrigerator Logo
81 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
jdthefixer
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
