Western Digital 500GB ELEMENTS 500 GB USB 2.0 Hard Drive Logo
Posted on Oct 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whats the input and output for a a power adapter needed to work a wd elements 500gb external hard drive?
Anonymous
Level 3:
Guru:
  • Master 2,178 Answers
  • Posted on Oct 28, 2010
Anonymous
Master
Level 3:
Guru:
Answers
2178
Questions
0
Helped
390423
Points
6614
Check the label affixed on the unit. It should indicate the power requirements. If not, go to the Western Digital website and locate the specifications for this particular model.
2helpful
2answers
I put 140G photos in my 500G WD element external HD. Now it is very slow and some files cannot be copied. What is the good way to get the data back? Thanks.
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
WD elements SE 1TB Portable hard drive will power up and disk will spin but not showing up in my computer....
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Note that W.D. has a "Customer Loyalty" program. Buy a new W.D. disk-drive through the W.D. web-site, and you'll get a significant discount.
1helpful
External Disk WD Elements problem
did u format the wd 320 gb already
you have to format it first to work from it
2helpful
2answers
WD ELEMENTS 1TB and the power supply is blinking
You have a bad power supply. You can probably get a new adapter for it.
1helpful
Where to find new power cable for my Wd elements wd5000e035?
Yes you can use any power cord that has the same output and input look on old plug to get input and output.
If this helped please respond my clicking yes it helped.
B52Computers
8helpful
2answers
I need to replace the power adaptor for a Maxtor One Touch 4 500 GB. I need to know the volt and amp output for it. PN:9NT2A4-500
Power Adapter for Mactor OneTouch 4
AC Input : 100 AC - 240 AC (50/60HZ)
DC Output ( V/A ) : 12V / 3.5A
Output Power : 42W
Replacement power cables
Can find them on eBay, if you can narrow down on the manufacture date. For the model I had, either Acbel AD6008 OR Asian Power Devices (APD) DA-30C01 work. I ordered a replacement which worked - but my real problem was needing a new hard drive casing. So now I have 2 power cords I don't need...but at least I have my data.
General problem
It could just be the 5-Pin AC Adapter. If you live in europe and your drive is still under warranty you can call WD and have them send one to you.
Top Western Digital Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Paul Bade
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
