Thank you for posting your question here on Fixya.com. The motor is likely failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft to see if it is damaged, bent, or the bearings failing or seized. If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced.
*All of this assumes this is an older/existing installation that has worked properly in the past and is just now showing signs of failure. If this is a new install look at your line voltage versus the voltage the motor is set to accept. If feeding 115 to a motor wired to be on 230 you will also get the situation you describe.
John
